normal engine temp ?
Old Sep 13, 2015 | 11:30 AM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
Default normal engine temp ?
What is normal engine temp for LS2?
Thank you
Old Sep 13, 2015 | 11:42 AM
wayback's Avatar
wayback
Depends on a lot of factors....outside temp, how hard your pressing the skinny pedal. .......
190 to 210 is common at speed, higher at idle in traffic.
Old Sep 14, 2015 | 08:05 AM
Boomer111's Avatar
Boomer111
Oil or coolant?
LS3 I see 189-203 (180 degree stat) coolant covering 99% of situations, moving or not. The oil once heated can be from 215-235. This is street driving.
I would assume your LS2 would be likewise.
Old Sep 14, 2015 | 08:08 AM
dryadsdad's Avatar
dryadsdad
Originally Posted by xlr8rvette
what is normal engine temp for ls2?
Thank you
200 f +/- 20.
Old Sep 14, 2015 | 03:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by Boomer111
Oil or coolant?
We had a 2006 LS2 and now a 2009 LS3, the temps are indeed almost identical.
With the stock 190'F thermostat, coolant runs 192-220 depending on driving condition, has never gone above 225 even in heavy traffic on a hot day.
Oil can take a loooong time to warm up, but eventually settles out 215-235 just like Boomer said. Typical on the interstates would be 215-225. If you start running high power and rpm in the twisties, oil can get to 250 rather quickly.
Our retired oil company engineer says best oil temp is 190-250, but reading the manual indicates GM doesn't think anything up to 302 is a problem.
Old Sep 14, 2015 | 05:16 PM
dryadsdad's Avatar
dryadsdad
Pure synth can go that high. Natural should not. Your numbers are right for both.
Old Sep 14, 2015 | 09:27 PM
mhatton222's Avatar
mhatton222
My LS2 oil temp goes to about 212 like clock work. Coolant temp a little over 200 standard.
To normal engine temp ?
