Charging Voltage
Old Sep 14, 2015 | 11:23 AM
Robert Anderson's Avatar
Robert Anderson
Default Charging Voltage
Is 14.4 to 14.8 normal charging range for my C6? THANKS!!
Old Sep 14, 2015 | 11:24 AM
dryadsdad's Avatar
dryadsdad
If it isn't, we're both abnormal. I think about 14.2 is correct. I suspect a slightly inaccurate gauge in mine.
Old Sep 14, 2015 | 11:27 AM
Don-Vette's Avatar
Don-Vette
Yes,normal
Old Sep 14, 2015 | 11:54 AM
RC4G's Avatar
RC4G
Unfortunately, normal. Also unfortunately can be hazardous to some aftermarket LED bulbs that can't handle sustained 14+ volts.
Went through two sets of non-switchback LED's under warranty with a former forum vendor. After the 2nd set died he refunded my money saying he wouldn't warranty a 3rd set, blaming my 2011 GrandSport's charging system (even though all C6's appear to charge at 14+ volts).
I purchased a different vendor's LED bulbs and have not had a failure since.
Old Sep 14, 2015 | 12:46 PM
EVRose's Avatar
EVRose
14.8 is too high. IMO.
Old Sep 14, 2015 | 03:34 PM
Hameister's Avatar
Hameister
2015 C6 of the Year Finalist
I've never seen 14.8v on mine.
I have seen 14.6v - 14.7v for a very brief time, (a couple of minutes), and then it will settle back down around 14.3v.
After a long drive, (several hours), it will drop to around 13.8v.
Don't know if that helps, but that's been my experience.
Old Sep 14, 2015 | 04:59 PM
wayback's Avatar
wayback
My OEM unit never showed 14.8 V. Seems high to me. My upgraded 170A is almost always at 14.6 V, never had a problem with my LEDS.
Old Sep 14, 2015 | 05:10 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Could be normal for your car. I have never seen mine quite that high (7 years) but for your car could be right. When I initially purchased my car I was on a road trip when the voltage went to 13 volts. I thought I might have a problem and went to a dealer who checked out the system and advised no problems. I learned at that time that the charge rate was controlled by the computer.
Old Sep 14, 2015 | 05:52 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
I see low 13s in traffic on hot days but 14.2 at cold start up.
Old Sep 14, 2015 | 08:39 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
On the low end I occasionally will see just under 12V in very hot weather, if I lower/raise the top and with the cooling fans on high, AC blasting and the Radio cranked.
14.5V is about the highest I've seen, when I was paying attention.
As far as LED's go, the ones I just bought to replace my fog lights are rated from ~12V-24V. Never had any problems with the LED tail lights.
Old Sep 14, 2015 | 08:42 PM
okie08vette's Avatar
okie08vette
I agree that 14.8 May be a little high. I see between 13.5 and 14.3.
Old Sep 15, 2015 | 07:56 AM
Robert Anderson
I just put a new battery in it and it has come down a little. I now see high 13's at idle but at speed I see 14.5-14.7. THANKS!
Old Sep 15, 2015 | 08:59 AM
extrapilot's Avatar
extrapilot
Have you seen this before the new battery?
It could be that your new battery was sitting in stock for awhile and in a state of discharge. This would be the only reason for higher than normal charging voltage.
Might want to check the actual voltage at the battery if you have a decent meter. The voltage reading will be slightly higher at the large terminal on the alternator than at the battery. A drop of about three tenths of a volt is common due to resistance in the wiring to the battery.
To Charging Voltage
