Help !
Old Sep 27, 2015 | 02:20 PM
Blacky Didi Molina's Avatar
Blacky Didi Molina
2nd Gear
Default Help !
My 2011 c6 grandsport is ideling bad and when I get to 3,000 rpms to shift it sounds like its miss fireing or sputtering and the engine light comes on and blinks when driving and the traction light also came on and I stopped by autozone and they said that it could be my spark plugs or wiring? Need help please !
Old Sep 27, 2015 | 02:26 PM
rado63's Avatar
rado63
Most common easy fix is to check that all plug wires are in place at the sparkplugs and on the coils. Easy to check, have to remove engine covers and check each connection.
Old Sep 27, 2015 | 02:53 PM
EVRose's Avatar
EVRose
Old Sep 27, 2015 | 02:56 PM
Don-Vette's Avatar
Don-Vette
Start with this!!^^^^:
Old Sep 27, 2015 | 04:56 PM
RicardoFors68's Avatar
RicardoFors68
Battery charging ok? Voltage issues? Ground issues?
Old Sep 27, 2015 | 05:11 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Before you do anything, read the error codes! The codes will get you pointed in the right direction. If you don't have an OBD II code reader, most auto parts stores will read the codes for you & you can look up the definition of each code on the 'net.
Old Sep 27, 2015 | 05:45 PM
ZR1 136's Avatar
ZR1 136
Spark plug wire.....same thing happened to me a month ago. Traction control, sounds like its running on 7 cylinders. Mine was the number 5 spark plug wire.
Old Sep 28, 2015 | 07:02 AM
RicardoFors68
Did you figure out what was the cause?
Old Sep 28, 2015 | 07:15 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Mine was doing the same thing, code P0300, I tried the wires and all was tight, I put new wires, still same, I have new plugs coming today so will change them, hopefully that will solve the issue. Mine only dos it when the car warms up though, its weird.
To Help !
