z51 options?
Old Sep 28, 2015 | 09:21 AM
KBu's Avatar
KBu
Default z51 options?
I know very little about corvettes other than I've always wanted one!Now I finally have one.How do you tell if the car has the Z51 option or not.The car I purchased has factory drilled disc and the front sway bar looks huge to me.Any help?Also,do all the auto transmissions use a 256 gear or do some have the 342?Thanks.Oh,car is '07.
Old Sep 28, 2015 | 09:27 AM
Hameister's Avatar
Hameister
2015 C6 of the Year Finalist
Look in your glove box, you'll see a sticker with all the codes that represent the car's equipment.
See if Z51 is listed.
Old Sep 28, 2015 | 09:34 AM
spdkilz911's Avatar
spdkilz911
That is the easiest way. Everything can be added if the previous owner wanted.
Old Sep 28, 2015 | 10:01 AM
Vette_DD's Avatar
Vette_DD
And those codes are listed in alphabetical order.
In some model years, non-Z51 cars also had drilled rotors.
Old Sep 28, 2015 | 10:14 AM
Cherokee Nation's Avatar
Cherokee Nation
The auto tranny has 273 gear and the manual 342 in the 2008 vette.
Old Sep 28, 2015 | 11:08 AM
KBu's Avatar
KBu
Z51 3LT.Thanks for the help.
Old Sep 28, 2015 | 11:12 AM
RicardoFors68's Avatar
RicardoFors68
My 06 has 2.56 gears and I think 2.73 started in 08
Old Sep 28, 2015 | 11:34 AM
Vette_DD's Avatar
Vette_DD
The 2.73 was optional (extra price) unless you had the Z51 option package. Then it was included with the rest of the Z51 option package.
Old Sep 28, 2015 | 11:47 AM
RicardoFors68
For all year models?
Old Sep 28, 2015 | 12:26 PM
grandsport2's Avatar
grandsport2
I could be wrong, but I think the 2.73 began in 2008. My z51 has it but I'm pretty sure the 06s and 07s I looked at did not.
Old Sep 28, 2015 | 12:39 PM
05 Wreck's Avatar
05 Wreck
Z51 vettes have zerk fittings (grease) on the tie rod ends front and rear.
Old Sep 28, 2015 | 01:09 PM
HOXXOH's Avatar
HOXXOH
J55 brakes with drilled rotors were a separate extra cost option in every year, unless they were included in either the Z51 or F55 option.
The 2.73 was included in the Z51 option or available as a separate option where the 2.56 was standard.
Correct. But it only lasted 3 years ('08-'10) in the base cars. It was standard in all GS A6 cars.
Correct, but see above.
Base cars all years had J55 brakes as a stand alone option.
Base cars with A6 had GU2 (2.73 gear) as a stand alone option in '08-'10 and included as part of the Z51 option in '08 and '09.
GS cars with A6 had the 2.73 standard '10-'13.
All this info is available on www.corvetteactioncenter.com, although it does require a bit of research and comparison of production numbers.
Old Sep 28, 2015 | 01:12 PM
cclive's Avatar
cclive
Good, now get out there and have some fun driving it!
Old Sep 28, 2015 | 01:57 PM
Cherokee Nation
Yes I know that..My has the Z51 stuff.
Old Sep 28, 2015 | 02:00 PM
Cherokee Nation
Only on the rear on my 08/Z51...
Old Sep 28, 2015 | 02:50 PM
RicardoFors68
Empowering and humbling knowledge...thanks
Old Sep 28, 2015 | 09:02 PM
GuyFromLeMans's Avatar
GuyFromLeMans
Here ya go:
To z51 options?
