Hint-
When entering an address in the C6 Nav; enter the city first, then the street name, then the street number. Seems to work much better that way and also tells you quicker if you have the wrong disc or wrong city or wrong region set..
That's the only way I get it to look up designations right for me.
Hint-
BTW, last I heard there have been no updates to the nav disc since the 2013 version came out in 2012. Is there anything newer?
We've used the factory nav for 130k+ miles over most of the US and Canada; I like it but will replace with aftermarket if there won't be any more updates. I don't mind an update every 2-3 years instead of yearly (saves me money), but after a while the lack of updates will be a deal killer.
I contacted a rep from gmnavdisc.com recently and was told that a new update from GM is due out in December. Hopefully she was correct
Thanks!
For the last 2 years, they have been saying that updates are released yearly, usually in the Fall. That was correct, except there have been no updates since the Fall of 2012.
