Why do people change out headers?
Old Oct 3, 2015 | 07:25 AM
EBvette02's Avatar
EBvette02
Default Why do people change out headers?
I know they do it for more HP. However wouldn't the engineers that designed the Corvette, design it with the best headers for the car? The same thing for exhaust and cai?
Just wondering.
Old Oct 3, 2015 | 07:48 AM
BadAV's Avatar
BadAV
The OEMs are doing a balancing act. Their main concern is decent performance with a long life on the parts.
Old Oct 3, 2015 | 07:51 AM
slayer6x6's Avatar
slayer6x6
Is also a balancing act with emissions and fuel mileage.
Old Oct 3, 2015 | 07:54 AM
RicardoFors68's Avatar
RicardoFors68
Noise, specific performance, fuel economy. Aftermarket stuff can alter these parameters. EPA and other govt agencies get in there deep
Old Oct 3, 2015 | 08:18 AM
Walt White Coupe's Avatar
Walt White Coupe
Because they have too much time and money. Performance improvement = miniscule
Old Oct 3, 2015 | 08:54 AM
TannerC15's Avatar
TannerC15
exhaust is a huge upgrade on these cars, I can't see how you'd call it minuscule.
Old Oct 3, 2015 | 09:18 AM
Boomer111's Avatar
Boomer111
Headers and a tune brought me 47 rwhp and 40 rwtq.
Not too bad for $$.
Old Oct 3, 2015 | 09:23 AM
wayback's Avatar
wayback
Just wondering.
Since when did any mass produced car use the best performance parts? At best there is a trade off between emissions and performance. .....we won't even talk about cost.
Many reasons to change.....performance, looks, and sound. All are better after swap.
Old Oct 3, 2015 | 09:37 AM
jesse82nc's Avatar
jesse82nc
Does any mass produced factory car actually use real headers? I have only seen normal exhaust manifolds, usually cast, used for factory cars. Headers are a bunch of tubes vs a manifold that is a much more inefficient design.
Old Oct 3, 2015 | 11:49 AM
68sixspeed's Avatar
68sixspeed
St. Jude 15 Year Donor
St. Jude Donor '10 thru '26
Cast manifolds are cheapest and less prone to have gasket leaks. (Less warranty work). They are also quieter. But they are no where near as efficient as headers. The ls7 exhaust manifold is a bit different, more efficient, so the gains there are not as great as with the ls3. But once the ls7 is modified (cam etc) even it gains pretty good with headers.
Old Oct 3, 2015 | 02:01 PM
djbrun's Avatar
djbrun
My co-workers 360 came with headers from the factory, but I wouldn't consider it mass produced.
DJ
Old Oct 3, 2015 | 02:25 PM
JRE-C6's Avatar
JRE-C6
Mid 80s till early 90s fox bodied 5.0 Mustangs had a tube style factory shorty header
Jim
Old Oct 3, 2015 | 02:36 PM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
it's more, not less.
Old Oct 3, 2015 | 03:12 PM
Z0HS1CK's Avatar
Z0HS1CK
Like someone said, for legal purposes. Noise, fuel efficiency, cost,longevity, etc.
Theres always more power to be had on any car.
Doing long tubes on my car was the best thing I did. I can't see how anyone can drive a vette on stock manifolds. My car was stock without the npp and I drove it like that for about a month and I was going nuts. There was no feedback. Felt like I was driving a manual Prius lol.
Then long tubes, no cats and a borla exhaust and its like all hell breaks loose each time I step on the throttle lol. I love it.
Old Oct 3, 2015 | 03:41 PM
Dano523's Avatar
Dano523
What headers do,
The down side, more noise, and the huge problem, it moves the Cats so far down line that they become less effective.
On the Zo6, it uses OEM shorter headers some what, which give a gain of around 15hp over cast manifolds, while the long tube headers end up with around a 25 to 30hp gain over the cast manifolds instead (better collector design over just longer tubes to be scavenged alone instead.
As for why all Vets don't have the oem shorter headers, it's called value engineering to keep the construction costs down on the lesser models like the base units, since the OEM cast manifold are much cheaper to make instead (and have very little scavenging effect instead).
To note, its not just the shorter headers on the LS-7 that holds back HP, but the size of the intake runners on the intake manifold as well. So the battle on the LS-7 to unleash it, it not to just install LT headers, but get a intake manifold on the motor that will allow it to breath correctly at top RPM's as well (and still fit under the hood as well).
So at the 504HP rating, it due to the motor being crippled, and not hard to end get an additional 60HP on the base motor with a tune, headers, and an intake manifold that will allow the engine to breath correctly at top RPM instead.
Old Oct 3, 2015 | 03:54 PM
Cherokee Nation's Avatar
Cherokee Nation
Jim
I had a 1986.
Old Oct 3, 2015 | 04:44 PM
Crabbers's Avatar
Crabbers
Emissions.
To Why do people change out headers?
Old Oct 3, 2015 | 05:35 PM
Dano523's Avatar
Dano523
Originally Posted by Crabbers
Emissions.
With the Z06 exhaust system Emissions legal in all states, it's more of a mater of value engineering production costs instead when it comes to the vet and the lower models.
Old Oct 3, 2015 | 07:41 PM
HOXXOH's Avatar
HOXXOH
You can thank () the tree huggers for the stuff we have to fix.
Old Oct 3, 2015 | 08:23 PM
ESSFO's Avatar
ESSFO
Originally Posted by Cherokee Nation
I had a 1986.
Even my 1993 Ford Lighting had factory headers.
