Winter storage
Old Oct 4, 2015 | 05:56 PM
Brian71's Avatar
Brian71
Default Winter storage
Hello all
I plan on putting my car away for the winter.
In the past I just removed the battery on my car (Porsche 911 no electronics).
With a C6 would it be better to get a Battery Tender to save all the electronic settings?
Or remove the battery and re-set everything in the spring?
What does the Corvette brain trust suggest?
Thanks in advance
Brian
Old Oct 4, 2015 | 06:04 PM
GASCAR's Avatar
GASCAR
Brian
I use the Ctek 3300 battery tender. I plug it into my cigarette lighter. I've been using it for five years. My vette is always kept plugged in.
Old Oct 4, 2015 | 06:05 PM
Z0HS1CK's Avatar
Z0HS1CK
I don't have an indoor garage, just a spot in the backyard of my parents house where i'll be keeping the vette (like last winter). Only mistake i did was that i was starting it up once a week to keep the battery from dying. I know that did more harm than good so this year i'm just disconnecting the battery and just doing a good once a month warm up. I really don't like the idea of keeping a car outside completely unstarted for the entire winter.
Old Oct 4, 2015 | 07:27 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Originally Posted by Brian71
Hello all
Thanks in advance
Brian
I have one of the cheapest battery float chargers from Battery Tender. Hook up to the battery, it keeps it charged and goes into standby mode once the battery is charged so not to over charge. I have used mine for about 3 years now and have not needed to replace the battery. Here is an example.
Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive
Your car will be fine without being started. Cold starting the car and not driving it doesn't really help anything. In fact, I think if I remember correctly, it was mentioned on here that it actually does more harm than good in the long run.
Just change the oil before storage, fill the gas tank, get a good outdoor car cover, try to cover entry points so little rodents don't make homes in your car, and if the car will be in storage longer than 5 months I would put fuel stabilizer in the gas tank.
Old Oct 4, 2015 | 08:01 PM
Red Tabby's Avatar
Red Tabby
When I put mine away for the winter, I disconnect the negative terminal. When spring comes around, the only thing I have to do is reindex the windows. I do not lose any radio or seat settings at all.
Old Oct 4, 2015 | 09:27 PM
EVRose's Avatar
EVRose
No presets will be lost.
Old Oct 4, 2015 | 11:19 PM
loco_stevie's Avatar
loco_stevie
Hello all
Thanks in advance
Brian
You have a lot of good advice already, I myself disconnect my negative battery terminals. Reindexing the windows is easy.
This way it's less taxing on the battery, your electrical bills etc etc.. specially for the long Canadian winters!!
On top of this, what I do is make sure that I use Shell premium as my last fill up, the only reason it is shell is because, it's the only brand with premium that guarantees it doesn't contain ethanol (at any percentage).
Also, if you plan on storing it more than 4 months, I will put some Stabil in it, make sure the fuel doesn't degrade.
Good luck, both of mine will be hibernating soon as well.
Old Oct 5, 2015 | 02:52 AM
nzkiwivet's Avatar
nzkiwivet
does anyone jack up their car for storage to take weight off the tires and wheel bearings etc?
Old Oct 5, 2015 | 06:49 AM
PAULEB07's Avatar
PAULEB07
I use a battery tender also for about three or four years now. No problems.
Old Oct 5, 2015 | 06:53 AM
blittle's Avatar
blittle
I use the same battery tender....works fine!! I also take it out once a month for a "careful" run....careful meaning the tires on my GS don't like cold weather AND i only go out if there is no snow, cinders and other crap on the roads....but that plan seems to work for me!
Old Oct 5, 2015 | 09:08 AM
RichKiss's Avatar
RichKiss
I bought a Snap On tender. Which means I paid 4 times as much as you can for one thru amazon. Probably made by the same Chinese factory and works just as good. Do a little research and get a cheapy.
Old Oct 5, 2015 | 09:43 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Fresh tank of gas and Ctek 3300 is all I have done for 8 years, that and sob a lot.
Old Oct 5, 2015 | 10:02 AM
EVRose's Avatar
EVRose
Unnecessary overkill.
Old Oct 5, 2015 | 10:04 AM
Tennis_pr0's Avatar
Tennis_pr0
Whats wrong with just leaving it sit and starting it up once every three or four days or so and just letting it run for a few?
Old Oct 5, 2015 | 11:23 AM
Welker1's Avatar
Welker1
When I was stationed in Utah & stored mine for winter, like others, all I did was fill the tank & disconnect the negative side.
Old Oct 5, 2015 | 11:48 AM
Don-Vette's Avatar
Don-Vette
My winter storage ritual. ....
Clean and wax car.
Do yearly oil change.
Fill tank and add bottle of Sta-Bil (storage) drive a few miles to circulate.
Pump up tires to 40lbs.
Connect battery tender.
Put cover on until Spring.
Old Oct 5, 2015 | 11:52 AM
tealex's Avatar
tealex
I store it but it is never stored to the point that I can't take it out on nice days. Full tank of gas with stabilizer, fresh oil change, battery charger on, tires up to about 34lb, washed, waxed and covered in the garage. When I have good days in the winter (clear skys, no snow, salt etc. on the roads) I take it out for long rides. When I gas up I add some stabilizer, wash it (if it needs it) and put it back in the garage the same way.
To Winter storage
Old Oct 5, 2015 | 12:00 PM
IDSRVIT's Avatar
IDSRVIT
With storing it outside, I'd be more worried about unwanted guests than anything else. Make sure you do something to prevent mice, rats, squirrels, cats, etc. from making your C6 a home for the winter.
Not sure if it would work outside but when I store my cars inside I put downy dryer sheets all around and under the car in the garage, as well as inside the car, engine bay and trunk area. You should at least put some inside the car, engine bay and trunk area. Outside I'd be tempted to plaster the ground with mouse traps / larger animal traps and check them frequently.
Nothing worse than electrical damage from a rodent.
Old Oct 5, 2015 | 12:13 PM
Mikado463's Avatar
Mikado463
Clean and wax car.
I agree Don. As for the Shell premium gas not having ethanol, not true here in the States, regardless, I know of no better gas than Shell
Old Oct 5, 2015 | 12:54 PM
Zero_6's Avatar
Zero_6
This is the first winter for my corvette and I have a 5 layer car cover. Keeps the rain away but not the bugs from going under. NC don't get much snow so I'm able to drive during the winter.
