ac compressor removal
Old Oct 4, 2015 | 09:54 PM
dalynchmob's Avatar
dalynchmob
Default ac compressor removal
Need to swap out my compressor. I've read where you can do it without removing the crossmember by removing the water pump instead. I'm looking at it and I'm wondering if it would be more accessible by removing the passenger side exhaust mani? Anyone done the water pump method or has anyone attempted the manifold removal?
Old Oct 5, 2015 | 08:13 AM
RoadkingC6's Avatar
RoadkingC6
Might get more answers in the C6 Tech/Performance section of the forum
Old Oct 5, 2015 | 08:41 AM
dalynchmob's Avatar
dalynchmob
Thanks, I can't figure out how to move it or delete it and repost. Perhaps one of the Mods could move it?
Old Oct 5, 2015 | 03:37 PM
HOXXOH's Avatar
HOXXOH
I found the most difficult part was removing the bolt that holds the freon lines. I wasn't trying to just remove the compressor, since I was pulling the engine, but either way, you still need to get that bolt out. The service manual shows it without the frame being in the way, which is no help whatsoever unless you drop the front cradle. I took an old socket and ground it off until it would slip in the space and then ground flats on the edges to fit an open end wrench. Once you get it turned a thread or two, you can spin it out with fingers.
If you try the exhaust drop method, be sure to post pics and a short write up. At least post up the results even if it doesn't work.
Old Oct 10, 2015 | 10:35 PM
dalynchmob's Avatar
dalynchmob
Well i gave it a shot and it worked. You can remove and replace your ac compressor by removing your passenger side exhaust manifold and cat. And the bolt holding the lines to the compressor was really easy to get. I'll do a write up with pics later.
Old Oct 11, 2015 | 01:46 AM
HOXXOH's Avatar
HOXXOH
Would I be correct by guessing that the bolt in question became easy once you lowered the compressor into the exhaust pipe area?
I'll be looking for the write up.
Old Oct 11, 2015 | 09:29 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
What about if you have headers? Easier or harder?
Old Oct 11, 2015 | 09:38 PM
truckplay's Avatar
truckplay
i hope you have not done that yet. if you remove the top radiator hose ( by the tstat) you can slide the compressor out the front. the whole job can be done in less than 1 hour with hand tools.
Old Oct 11, 2015 | 10:36 PM
dalynchmob's Avatar
dalynchmob
No once I removed the cat pipe I was able to crack the line bolt loose from underneath. It protrudes beyond the line block just enough to get a straight box end ratchet wrench on it.
C U- I imagine headers would probably be harder? Not sure I'm running stock exhaust to the axle.
truckplay- I was just looking for a different option and didn't want antifreeze all over. She's all back together now. After I sprayed all the bolts with pb blaster and let them sit for 2 hrs while I ate dinner and put the twins down, it was rather easy. Prob didn't get it done in an hour though, but I did the condenser too.
I'll post it as another alternative to dropping the CM.
Old Nov 24, 2018 | 10:02 AM
fourth vette's Avatar
fourth vette
Default Easy job.
Drain radiator. Remove 3 hoses and thermostat housing. Car on ramps and remove passenger tire. Remove 2 lower compressor bolts. Remove 2 upper bolts. Slide compressor forward and rotate to remove lines. Loosen motor mount bolt and jack up engine about 1 inch. Compressor comes out very easy. Make sure you replace mounting stud before you reinstall compressor. I'm 72 and took anout 3 hours to remove and replace.
Old Nov 25, 2018 | 11:59 AM
racerx3317's Avatar
racerx3317
Thanks for reviving this old thread. I gotta change mine soon. I'm getting a high RPM whine with the AC on. I almost replaced the clutch for no damned reason.
Old Feb 6, 2019 | 07:40 PM
smithdb1960's Avatar
smithdb1960
2nd Gear
Default AC Clutch Replacement
Anyone know if the AC clutch is replaceable on a C6 Grand Sport?
To ac compressor removal
