A6 overheating question
Old Oct 10, 2015 | 11:22 AM
Stingray Al's Avatar
Stingray Al
Default A6 overheating question
I have read numerous threads re automatic transmission overheating issues. My A6 overheated on the track a few weeks ago. I know GM promised to come out with a "fix".
However,
Has anyone tried Redline or Amsoil ATF ?
Old Oct 10, 2015 | 10:08 PM
Stingray Al
anyone??
anyone try a different ATF fluid???
Old Oct 10, 2015 | 10:31 PM
berk4422's Avatar
berk4422
How hot did it get? I have not tried different fluid. My fix was an aftermarket B&M cooler post Radiator out. Also, have you cleaned your radiator lately by taking off the top shroud and getting between the condenser and radiator?
Old Oct 11, 2015 | 07:26 AM
Don-Vette's Avatar
Don-Vette
I haven't heard of any overheating issues with the C6. When I ran Tail of the Dragon, my temp did go up a little. Since you track your car,you can have the fans turn on sooner when it's tuned.
Old Oct 11, 2015 | 05:41 PM
Stingray Al
I had this post in the c7 section. I have a 2014 c7. The moderator moved it to the c6 section. I have no clue why it was moved here
Sorry guys.
Al
Old Oct 11, 2015 | 06:15 PM
HOXXOH's Avatar
HOXXOH
Sorry guys.
Al
Most likely, that the A6 had an 8 year run in the C6 and only 1 year in C7, so more info is here than there.
So how hot did it get? And after how long at what speeds on what type of track?
Old Oct 11, 2015 | 06:37 PM
Stingray Al
It went into "limp" mode around 300 degrees. There is a company that makes a larger transmission pan. I might go that route.
Old Oct 11, 2015 | 07:51 PM
HOXXOH's Avatar
HOXXOH
Better to put the extra capacity into a cooler instead of the pan. Many of us drag racers run 1/2 to 1 quart over full, just to assure there is always enough in the converter at high RPM.
Old Oct 11, 2015 | 10:03 PM
ErnieN85's Avatar
ErnieN85
LG racing (forum vendor) has a trans cooler package for C7
give them a call
To A6 overheating question
