Heavy steering effort
Your point is valid, but why does steering have to be heavy at 5 mph or even 55 mph? Steering effort has been adjustable by ECM and valving for many years. My 1994 Pontiac Bonneville SSEi (supercharged) had ECM-adjusted steering effort it and it worked pretty good.... light steering effort at low speeds and then effort increased with high speeds.
This whole thing about heavy steering really kills many modern cars for me. We spend 99.99% of our time driving around at safe, slow speeds. At those speeds, steering should be relatively light.
Peace.....
Peace.....
I figured i give it a shot,, As i see alot of pump's changed because of leaks.. Mine isn't.
Gotta try something.. As it is now, if i come into a curve that everyone can fly into and out of .. and i have to let off gas going into - NO GOOD..
Seems mine is worse than other's on here.
Still waiting for corvette club here , and a member to contact me.. So as to compare veh's..
Unhook connector and at the connector (wire to rack) -- (Make sure it's the rack side of connector) - Use a ohm meter and hook to both ! connector terminal's..
And should read between 1.6 -3.1 ohms.. Or better yet-- 2 ohms.
Then with ohm meter,- hook one lead to one of the wire's in the connector
And then hook other wire from ohm meter to rack. -
This checks for the coils in rack being shorted to ground. (BAD)
Then do the same with the second wire in the connector..
Stupid me havent done it yet,, and i ordered pump today...
Just found this info a few ours ago..
1. Recommended tire is too low
2. I set mine to 37-38 psi with a tire gauge not the tire pressure monitor system. TPS on my reads about 2 + psi low
The higher pressure helped a lot
One other benefit is that the tires, rear for sure, will wear better as the middle of the wide tire will have better contact with the ground.
Give it a try, what do you have to lose?
When i had rear tires put on the car, the garage set them at 37 cold and that was way to hard and also lack of traction... and car bounce over bumps.
