Harmonic balancer problems
Old Oct 15, 2015 | 06:06 PM
HBsurfer's Avatar
HBsurfer
Originally Posted by gmtech1234
I think the problem is the belt is driven off the outside of the ballancer. The older design had the belt driven off the inside of the ballancer & that put no stress on the rubber. The Vette has no room for a pulley on the front of the ballancer.
This makes a lot of sense to me.
Old Oct 15, 2015 | 07:16 PM
Bruze's Avatar
Bruze
Me too, and it's the first thing I've seen in all these HB threads that makes sense as to WHY it happens -- aside from faulty materials and/or shoddy manufacturing processes.
But that begs the question: Was the same HB put on other cars besides the C6? Do they have around the same amount of failures? GMtech is more or less saying that they were designed specifically for the Corvette.
Old Oct 15, 2015 | 07:25 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
The balancer problem has been around since the first Corvette LS1 engine back in 1997.
You may have also heard of problems with the needle bearings in the rocker arms falling out ... That too has been around since the 1997 LS1 engine, although not very common as of lately.
Old Oct 16, 2015 | 10:18 AM
njedwardz's Avatar
njedwardz
My '13 LS3 base car started to get a pretty bad wobble early this year. Replaced with an ATI and never looked back. Incredible difference in build quality (also 10x more expensive). I imagine the problem becomes more common when you're hard on the car, which I am.
Old Oct 16, 2015 | 10:25 AM
Cor430vette's Avatar
Cor430vette
The poll shows 67%. So keep an eye on it...but figure the probability is low and it does not cause catastrophic engine damage. Plus froggy on youtube shows you how to do it yourself even so who cares? ....
Old Oct 16, 2015 | 12:16 PM
HBsurfer's Avatar
HBsurfer
10 times more expensive? My ATI cost about $400. Don't want to be a dick but that comment could scare a lot of people away from buying a far superior product for only a couple of hundred dollars more. Small change considering the overall cost of the work and what you get for the money.
Old Oct 16, 2015 | 02:57 PM
windyC6's Avatar
windyC6
Originally Posted by Bruze
Great post windy, as usual.
I can't think of all the GM vehicles I've had in my lifetime (which most of them were) but they run from the first being a 1961 Corvair and the last (excluding the C6) was a 1998 S-10.
NOT ONE ISSUE with harmonic balancers, but NOW they can't get them right? -- and, as you said, the problem is mostly on their flagship car?
I've also had several Fords, one Plymouth, and numerous J.a.p. trucks -- no HB issues.
Well...Well...Well BRUZE.....we had one of those early sixties"Air-Vairs" too...LOL. can't remember what year it was. It was the first car I ever drove and subsequently learned to drive on. Ol 3-speed manual on the floor. I personally loved the thing, Who cares if it threw a little oil all over the rear bumper and things...LOLOL. And I guess the heater could have worked a little better. But what the heck did I know back then....LOL. And just between you and I...did they even have a harmonic balancer...LOL. I guess it could have been tucked up under there somewhere. As far as the balancers on our C-6's....some good thoughts in here to be sure, its just a crying shame we pay good $$$ for these things and what should be one of the most reliable parts shoots craps........in my opinion...
Old Oct 16, 2015 | 09:46 PM
Bruze's Avatar
Bruze
Yup, mine was a 3-on-the-floor also. And leak oil? -- wow. I paid $75 for mine and it would leave a puddle a couple of feet in diameter under the engine. I bought "remanufactured" oil from Noah's Ark for, I don't know, maybe half a buck for a gallon can.
It was the "rear" (front actually) main seal and after beating the crap out of it for a couple of days the tranny input shaft snapped. I had to take it apart at that point and fix it, and of course replaced the seal too.
My dad picked up the input shaft at a Chevy dealer's and I'm quite sure it was like $9.95 (that was about 2/3 of a week's pay for me). All in all it was a good learning experience for a dumb teenager.
I'm sure it had a HB, although it would have been on the rear of the engine. No trouble with THAT though.
Old Oct 17, 2015 | 01:04 AM
Magik's Avatar
Magik
Is there a particular model number for the ATI HB for our C6 Vettes?
I looked online, and there seems to be many different models. Thanks in advance.
Old Oct 17, 2015 | 09:54 AM
clearwaterms's Avatar
clearwaterms
what do shops typically charge to install the ATI? can they key it with the motor in the car?
Old Oct 17, 2015 | 11:35 AM
windyC6's Avatar
windyC6
Yea....and I bet the HB was probably soaked in oil and still performed flawlessly....LOL. If memory serves, didn't they have the V-belt routed in a way that had that 90 degree turn in it ?...or am I thinking of another rear engine beast ? Every time I see one for sale I think to myself...."do I want this thing for ol times sake ?"......and then reality kicks in and I say "Nah". But i do like your solution to the oil problem by using re-ferbed oil. A smart/frugal way to address the issue.
Old Oct 17, 2015 | 12:05 PM
Bruze's Avatar
Bruze
The HB would have been at the rear of the car, and the "rear" main seal was on the front of the engine where the transaxle was.
I was trying to picture the v-belt system and I think you're right -- it had a right angle in it. Not sure why, all it drove was the alternator on mine, not even sure if PS was an option then.
LOL, "remanufactured" oil -- okay for a $75 car, wouldn't recommend putting it in a Vette.
Old Oct 17, 2015 | 01:02 PM
  #33
Gering's Avatar
Gering
Tolero Apto Victum
Check out these two links: http://store.katechengines.com/bille...sioner-p2.aspx & http://store.katechengines.com/dampers-c41.aspx
Old Oct 17, 2015 | 06:05 PM
  #34
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
They had an air cooling blower fan on top of the motor that the belt turned. That bearing failed often.
