MUSICSTREAM! Add BT Audio to your C6 AUX port on Factory Radio for $29.99!
Former Vendor
I have a limited supply of the new ISBT23 MUSICSTREAM BT Audio kit from PAC Audio.
Once this first order is gone they will not be available again till middle of November.
This install kit will allow you to add BT Audio streaming from your cell phone by using the AUX port on your stock radio.
Simple Power and ground connection and then plug and play for rest of the install.
WILL NOT work with AUX to USB connection for those with the console USB.
$29.99
CLICK HERE TO ORDER
Bluetooth audio receiver to transmit music from a phone to any car, boat, or motorcycle with an AUX input or direct to amplifier.
4V output and weather-proof for all your adventures on the road, off road or on the water!
Bluetooth receiver featuring a weather-proof housing
Male 3.5mm to female RCA Converter
3pc weather proofing heat shrink
Coated PCB boards
Fully sealer housing for weather proofing
Small enough to be installed in limited space
4V RCA Output
Easy two wire installation
Coated PCB boards
4V RCA Output
