trunk, push button opener
Old Oct 22, 2015 | 07:10 AM
Dark-Knight's Avatar
Dark-Knight
Default trunk, push button opener
I have an '08 vert, great ride!
the push button is located just above the rear lisence plate, and it just quit working. the button on the key fob still works.
Any suggestions for repair?
Thx in advance guys!!!
Old Oct 22, 2015 | 07:43 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Seems like I've read a thread on here that the button's wiring may get corroded and need cleaning.
I never use that button ... had forgotten that it was even there. I always use either the one on the dash or the fob. Not even sure if mine works.
Old Oct 22, 2015 | 07:48 AM
Kenny94945's Avatar
Kenny94945
Common issue.
Do a search for instructions (remove rubber cap/ clean contacts).
Many successfully just clean it.
Replacement is cheap and easy.
Old Oct 22, 2015 | 08:51 AM
4SUMERZ's Avatar
4SUMERZ
Here is a PDF that might help you out. Forum Member RedLion did this repair many years ago.
File Type: pdf
Old Oct 22, 2015 | 01:11 PM
Bat66's Avatar
Bat66
Easy and simple fix just follow RedLion pdf, you'll be surprised at how much dirt is under that rubber.
Old Oct 22, 2015 | 08:25 PM
RICH 28's Avatar
RICH 28
It worked for me.
Old Oct 22, 2015 | 09:44 PM
jdlew's Avatar
jdlew
if cleaning don't fix it for you (it didn't work for me)... here you go
http://www.ebay.com/itm/05-13-C6-Cor...-/190696430223
one of the few things that isn't to bad on price
Old Oct 22, 2015 | 11:59 PM
owc6's Avatar
owc6
While you're at it check to see that your key still works. The keyhole is notorious for filling up with dirt and road grime, and then not working when really needed.
Old Oct 23, 2015 | 06:25 AM
Dano523's Avatar
Dano523
The button is easy to pull, but if you plan on cleaning the button, it needs to be pulled down to this level so clean the electrical contacts as well. Also, do not lube the button in any way, since the lube will just attract dust back into it even faster.
Old Oct 23, 2015 | 06:57 AM
USAF's Avatar
USAF
There's a button?
Who knew??
USAF
Old Oct 23, 2015 | 12:08 PM
4SUMERZ's Avatar
4SUMERZ
Originally Posted by USAF
There's a button?
Who knew??
USAF
Old Oct 23, 2015 | 12:19 PM
EVRose's Avatar
EVRose
There's a button?
Who knew??
USAF
I did.
To trunk, push button opener
