Which Techron?
Old Oct 23, 2015 | 01:49 PM
shakinrock's Avatar
shakinrock
Default Which Techron?
I'm having the well documented "Service Fuel System" issue. I'm going to try to add Techron since about half the time I do not use Top Tier gasoline.
I noticed there are two different Techron products. One labeled "Fuel Injector Cleaner" and the other "Complete Fuel System Cleaner".
There is a noticeable price difference between the two. Any recommendations please?
Old Oct 23, 2015 | 02:41 PM
gaphono's Avatar
gaphono
Old Oct 23, 2015 | 02:49 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
You know the left tank fills first and then the right tank. I don't know if it helps but I add some before I fill and the rest after.
Old Oct 23, 2015 | 03:07 PM
NoRuls's Avatar
NoRuls
Read my post #41 on the Which gas do you use? I had similar problems.
Old Oct 23, 2015 | 04:12 PM
jacktucky's Avatar
jacktucky
if you are not having problems does it make sense to use Techron? I mostly use Thorntons gas, BP sometimes.
Old Oct 23, 2015 | 04:34 PM
cor28vettes's Avatar
cor28vettes
a.k.a. Concentrate Plus
www.techronworks.com
click ask our experts
then follow directions
Old Oct 24, 2015 | 08:30 AM
shakinrock's Avatar
shakinrock
Well the longer version of the story goes like this. My '07 6M Z51 vert did experience the issue where the gas gauge went crazy after a fill up. It jumped back and forth from 2/3rds full (again after a fill up) to empty.
This continued until the Check Engine Light came on. After burning off about 1/4 tank and about a half dozen starts and stops the gauge self corrected. Then after a few more starts and stops the Check Engine Light went away. I was getting the infamous P2068 code. I do not use Top Tier gas about half the time due to my location
So after reading this forum I decided to try Techron, Complete Fuel System. I ran one 12 oz bottle twice with two consecutive fill ups. The situation has improved as a result.
Now when I fill up the gas gauge is crazy for only about 15 miles and then self corrects even if I do not turn the car off. It self corrects so quickly (I'm guessing) that the CEL never illuminates.
So I want to run a few more bottles to see if I can make the issue completely go away. I noticed that the Fuel Injector Cleaner product is far less expensive then the Complete product.
However based on the comments already made in this thread I guess I'll bite the bullet.
Old Oct 24, 2015 | 08:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
"GM Fuel System Treatment Plus" is said to be re-branded Techron, bottle has a Chevron symbol on the bottom.
Probably more expensive, but easier to find sometimes.
Old Oct 25, 2015 | 04:33 PM
cor28vettes
Same same stuff. Just look for Concentrate Plus on the front label in smaller letters.
10 oz will treat 15 gall so get more.
Wally world had it for $5 no long ago.
Costco $20 for 6-pack I heard
Amazon on the cheap as well.
follow directions on back
Old Oct 26, 2015 | 08:48 AM
shakinrock's Avatar
shakinrock
The $20 product at Costco is a 6 - pack of Fuel Injector Cleaner, not Concentrate Plus. That's why I started this thread. I made the purchase at Costco and then realized I bought Fuel Injector Cleaner, not Concentrate Plus.
To Which Techron?
