HUD install issues..
Old Oct 25, 2015 | 07:06 PM
xyoung347x's Avatar
xyoung347x
Banned Scam/Spammer
Default HUD install issues..
Got a used HUD system off of an 07 C6 and trying to put in my 08 C6 LT1. Everything is going smooth except for the wiring part. I initially going to do the "Cut the Duct" route but I couldn't come to hacking up my vent so I went with "Cut the leg off of the Projector" route. I self tap two screws in a plastic piece I had laying around. (Once everything is good, I'm going to JB weld/glue it for more support.) I wired everything from http://www.theredlion.us/C6%20HUD%20...%20Rev%202.pdf but got nothing. The car didn't want to turn on so I start guessing which wires is causing the issue. I start to cut and resplice back to determine which wire it is. First I tried the engine speed signal, the vehicle speed signal, then the IPC Class 2 Serial Data and it fired up but the HUD is off. So I'm guessing its has something to do with the IPC Class 2 Serial Data? Any help? I have and still using the search button and google and haven't found much. Picture below is the hud and what I tapped into.
Mickey Mouse HUD support bracket.
