Mirror Guts
Thanks, for any help
jlong86 had a problem with his sideview mirror vandalized in 10/14: "Some jerk took only the dimming glass from my passenger side mirror. The housing and electronics are still there from behind the actual glass.
I've searched the forum and cannot find anything on point. I purchased just the glass online (item 3: http://www.gmpartsdepartment.com/par...agramCallOut=3)
Does anyone have any experience putting this thing back on? I'm not sure if it just snaps into place after connecting the power cords. I'm not sure if the thief broke one of the moving parts that adjust the mirror too. I can't find a picture online of the electrical assembly.
I'm wondering if it's worth it to have the dealer install.
Thanks"
here's another site and pdf to look at for installations. http://shop.muthco.com/content/pdf/install/21001440.pdf
markcz (tech contributor--you may want to contact him for hints on how to do it) posted this when jlong had trouble putting the glass back in: "It's not broken, you're just missing the 'peg' that goes between the mirror and the motor.
Try contacting one of the used parts places for a replacement."
Re pushing the mirror back onto the "pegs," I know from personal experience that you kind of have to have the knack for it. It's a very easy, and even push along the face of the glass so that it pops over the pins, but not break. Just be careful.
Hope this helps you; nice thing you're doing for your friend.
1. the actuator/motor is held in the body of the mirror casing with torx screws. However, the inside door panel must be removed to remove the mirror so you can run the new actuator wire harness. If you are just removing and replacing the mirror glass portion it’s easy. The re-installation is tricky… use a small piece wood on the mirror side to prevent crack the glass. Position the actuator legs carefully into the actuator and align the center swivel mount and press the mirror into place. I hope this helps.
https://www.youtube.com/watch?v=ysvAzQpRBPg#ddg-play
