Trying to install a hud in my LT1 08. got it off a LT3 07 C6. I wired everything correctly but once have the HUD class 2 Serial Data, car will not start. Can anyone help?
Sounds like something is disconnected or maybe the battery died? Can't think of why the HUD would prevent the car starting, double check your wiring if that's correct. Disconnect the HUD and see if car will start. Not much help I know, when I installed the HUD in my 08 the wiring was simple, I would suspect a connect has come loose.
I triple check. everything about 5 times now. The only thing that will cause the car to fire up is the HUD Class 2 Serial Data to be disconnected. The six loose end coming from the Blue connector (HUD switch) and the brown connector (HUD projector) that is tapped into the gray and black IPC connectors are...
battery
ground
vehicle speed
engine speed
IP lamp supply voltage -2
everytime I discount only the HUD Class 2 Serial Data, the car will start.
