2011 c6 corvette active steering sensor
Old Nov 4, 2015 | 02:32 PM
dpcomm's Avatar
dpcomm
1st Gear
Default 2011 c6 corvette active steering sensor
the active sensor on the steering column is moving on the column with the bearing, the bearing is also moving in and out not staying in place, causing the system to control the brakes when I turn, I tried to move the bearing but will not sliding back in place like its stuck
