I broke part of the "TEE' that connects the 3 hoses together part of the cooling system. The part that broke is for the hose that goes to the tank where you add coolant. I just went to O'Rellys and they have a ton of tees,bur not the one for the vette. Sucks!! I read some posts awhile back about where some guys get that TEE. Online it looks like you have to buy the complete unit..3 hoses and the tee..Thanks
Local plumbing supply might have one that will get you going, until you are able to locate the correct part. Home Depot and Lowes have a selection too.
And don't forget Ace. There is a huge Ace in Tucson that has a ton of the plastic tee's, etc...
Can you take a picture of the piece? I have been looking online but not finding a picture to what you are describing.
I can't upload photos on this computer. Go on Gmpartshouse web site and look at the coolant system and It's the #15 picture. You can not buy the tee you have to buy all 3 pieces I guess?. Look under your hood and follow the 3/8" hose that connects to the top rear of the coolant tank it tees off under the air box,and a 1/4" hose goes to the engine next to the TB and another 3/8" hose goes to the top of the right side tank. I've asked the dealer what that setup is for and he did not know either? Maybe you have a answer..Thanks if you can help.
that setup is to vent the top of the engine so you won't get an air bubble
more than likely a good hardware store could put together the pieces to make one with brass
I broke that piece too. It's plastic and gets brittle with age because it is constantly exposed to hot coolant. Any garden variety tee fitting with two 3/8 barb fittings and one 1/4 or 5/16 barb will work (I'm guessing on the sizes, measure your hoses). Check out Lowes (where I got mine) or maybe a variety pack of plastic vacuum tees, since that's a relatively common size. If you're having trouble I'd be happy to dig around in my collection and look, and you can always find them on Amazon too.
I went to 3 different auto parts stores yesterday and also Home Depo could not find a setup made of plastic, last stop was Ace hardware and the guy put together 4 pieces of brass that will work but it is heavy and I will need to cut a little bit off the 2- 3/8"s hoses to get it centered to line up with the 1/4" hose going to the engine. Like I said if you want the OEM tee you have to buy all 3 hoses and the Tee comes with them for over $100.00 that is BS!..Where on Amazon should I search for what I need in plastic...Thanks
I started my vette up without that setup on the car and very little coolant came out, but it was not up to temperature when I did the test.
I did a quick search and eBay has a pack of ten 3/8-3/8-1/4 for less than four dollars. There is also Fresh Water Systems that has a large selection of fittings.
it isn't the coolant that comes out that is important, it is that the air will.
if you use plastic make sure it is rated for hot water. there are plastic fittings which are only good for cold water and they are in the majority.
They're not difficult to find. If you find one that's pre-made in brass I recommend it since you'll never have to worry about it breaking again.
I searched Fresh Water Systems and found one 3/8 X 3/8 X 1/4,but reading below it, Not Rated For Over 200F Sh@t.Like said in the post above all the plastic fitting are not rated for hot water. I'm going to use the brass setup I got at Ace. It will not only last forever, but it looks good. Polished Brass.Thanks guys for your input..
The ones at auto parts are mainly for vacuum lines...
