A 2005 is not a C5. The only thing that will need a reboot will be the windows, and MAYBE the clock.
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
This will need to be done to both windows every time the car battery is disconnected, then reconnected.
