Starting issue
Old Nov 16, 2015 | 01:42 PM
Jimmie43's Avatar
Jimmie43
3rd Gear
Default Starting issue
My 05 C-6 has starting issues usually in the mornings. Any ideas?
Old Nov 16, 2015 | 02:09 PM
EVRose's Avatar
EVRose
A little more detail would help but first guess is weak battery.
Old Nov 16, 2015 | 02:13 PM
cclive's Avatar
cclive
"Starting issues" is just too vague for us to give any meaningful help...
Old Nov 16, 2015 | 02:17 PM
HK770's Avatar
HK770
Hard to advise, you suppose its caused by the weather?
Old Nov 16, 2015 | 02:20 PM
4SUMERZ's Avatar
4SUMERZ
Without knowing any details, step 1 is to get your battery load tested.
If that's fine, then look at the battery connections. If that's OK, then look at the starter connections, especially the solenoid connections. If your running headers, the heat causes the connectors to become brittle and crack.
Other than that, can't help anymore
Good Luck
Old Nov 16, 2015 | 02:28 PM
HBsurfer's Avatar
HBsurfer
is it cranking over and slow to start up or does it not crank at all? More info needed.
Old Nov 16, 2015 | 04:16 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Morning sickness...
Old Nov 16, 2015 | 07:34 PM
Jimmie43's Avatar
Jimmie43
3rd Gear
Default starting issues
Originally Posted by ruxvette
Morning sickness...
sorry...more specific. When i try the starter button (mornings only so far) if it does not respond, I go back to off and then start again. Usually works. If not I disconnect the negative on the battery and it will start.
Old Nov 16, 2015 | 07:37 PM
Jimmie43's Avatar
Jimmie43
3rd Gear
The starter button does nothing. All else is working. I try start, if that does not work, I go back to "off" and then to start. Usually works. If not, disconnect the negative on battery and it will start. So far....
To Starting issue
