How to reset code
Old Nov 21, 2015 | 03:49 PM
stp357's Avatar
stp357
Default How to reset code
I had a (not sure what it is called) thing that looked like a spark plug wire type deal come off. Caused the engine to start ticking like a valve had failed and running really badly. I stuck it back on, but the engine icon is still on the dash. How do I get it to go away.
Old Nov 21, 2015 | 03:57 PM
unclecookie's Avatar
unclecookie
Not sure on the Corvette, but on my wife's BMW, if the check engine light comes on, and then the problem is fixed (such as a loose gas cap that is tightened), the light will go out after "X" number of ignition cycles. If that doesn't work on the Corvette, then you may need someone with a scan tool to reset it for you.
Old Nov 21, 2015 | 04:43 PM
Zero_6's Avatar
Zero_6
Disconnect and reconnect the battery cable, either one or both.
Old Nov 21, 2015 | 04:46 PM
Daviddear30's Avatar
Daviddear30
get a bluetooth/obd2 adapter ($10-15)and use it with a smart phone. I have used mine for years. You can check codes and clear them run diagnostics etc.
The app i use is torque.
Old Nov 21, 2015 | 04:49 PM
extrapilot's Avatar
extrapilot
Cheap enough, or just drive and a few drive cycles should clear it's self.
Old Nov 21, 2015 | 04:57 PM
Vette_DD's Avatar
Vette_DD
Just remember that this process requires you reset the window indexing after the car battery is reconnected.
Old Nov 21, 2015 | 05:00 PM
Zero_6's Avatar
Zero_6
I didn't have to for mine.
Old Nov 21, 2015 | 05:19 PM
extrapilot's Avatar
extrapilot
This would be unusual not to have to re-index the windows.
Old Nov 21, 2015 | 05:28 PM
Vette_DD's Avatar
Vette_DD
May be a function of how long the battery is disconnected.
Old Nov 21, 2015 | 05:35 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Kinda of getting off post...but I have changed batteries and never re-indexed the windows.
To the OP...drive it a few times and the code will go away.
Old Nov 21, 2015 | 06:19 PM
Dcasole's Avatar
Dcasole
I bought a cheap scan tool off of Amazon . less than $30.00
it reads and resets all codes
Dave
Old Nov 22, 2015 | 10:45 AM
Rogers 07's Avatar
Rogers 07
This is what black electrical tape is for, just cut off a 1" long piece, place it over the orange light on the dash and you will never again have a check engine problem. It also works well on electronic equipment with clocks that blink 12:00 all the time as well.....
Old Nov 22, 2015 | 12:39 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Can you get that in carbon fiber for extra classy look?
Old Nov 22, 2015 | 01:00 PM
Racer86's Avatar
Racer86
Sure, autozone, stick on carbon pattern vinyl sheets, you cut to fit.
Old Nov 22, 2015 | 03:14 PM
Rogers 07's Avatar
Rogers 07
Damn, wish I'd thought of that, Stronger and better performance!
Old Nov 23, 2015 | 12:34 AM
Grimlock13's Avatar
Grimlock13
Had that happen to me also, I drove it 3 times, have to shut down in between and let sit for 30 minutes at least and it turned off it.
So if it is now running fine and you have no messages pop up at start, ie. Traction control off or active handling off, then just drive it and it will reset itself.
To How to reset code
