New Active Handling Problem, Help please
Old Nov 22, 2015 | 09:25 AM
jdlew's Avatar
jdlew
Default New Active Handling Problem, Help please
I was picking my daughter up from work the other night. It was rather cold outside, so I sat in the car with it at idle running the heater. Like any normal person would do. It took her a little longer than usual for the manager to release them from closing/ cleaning the store, so i was outside waiting for about an hour with the car running. The car never got over 220 degree, but as soon as she got in the car and we started to leave the parking lot, I would go about 20 feet and the front right brake would lock up and stop the car. Active Handling would come up on the DIC. As soon as the car stopped it would go away and I would be able to move again 20 feet at a time. To be able to get home I had to reach over and hold the Traction Control button to cut it all off. I was able to get home without another issue. The next day there wasn't any more problems with it.
Question would be what would have gotten hot enough to cause active handling to kick in from me sitting in the parking lot idling? Any help would be appreciated.
Old Nov 22, 2015 | 09:49 AM
icntdrv55's Avatar
icntdrv55
Car equipped with the F55 shocks? Could possibly be the sensor/wiring got too hot from engine/exhaust header heat? Definitely an odd glitch...
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Or, did your battery become discharged enough to cause it? An hour with the engine running, lights on, radio on, heater fan on...
Old Nov 22, 2015 | 10:50 AM
jdlew's Avatar
jdlew
Its a Z51 car, i was thinking heat transfer form engine bay to steering wheel sensor under dash.
Old Nov 22, 2015 | 10:54 AM
jdlew's Avatar
jdlew
the radio was on as well as the heater fan on low, i had the lights off. never seen a dip with the alternator but it is a possibility, I really dont wont to go through the process again to see if i can duplicate it. not a very nice feeling being 20 miles from home at 1 in the morning and the car wont let you move.
Old Nov 23, 2015 | 05:27 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Did you try shutting the car off then re-starting it.
This process has cleared some odd 'glitches' for me in the past.
Old Nov 23, 2015 | 07:15 PM
jdlew's Avatar
jdlew
I tried doing that a couple of times, but it didn't do me any good unfortunately.
Old Nov 23, 2015 | 10:03 PM
CSixDude's Avatar
CSixDude
There is a connector under the dash for the steering wheel angle sensor that has had issues on many cars, and there is a TSB out on it. It is a poorly designed connector, and when it looses contact, it causes issues similar to what you describe. I believe it even was the subject of a recall. Some folks had cars change lanes on them at 70mph when it failed.
GM started installing a comb shaped clip in the connector to try to improve the contact pressure. I think if mine ever gives me problems, I'll just cut the connector out entirely and solder and heat shrink the wires together.
Old Nov 23, 2015 | 10:23 PM
4SUMERZ's Avatar
4SUMERZ
The TSB was for the 2005-2006 Corvettes, but could affect others as well. Here is the TSB for it and the fix with pictures. I don't believe it was ever a recall, although if not, it should have been.
The issue was more noticeable with cars with telescoping steering which would stretch the wires and make them loose connection.
Even with the so called comb clip, it's still possible to have issues.
The fix wraps electrical tape on the clip and wires, then tie wraps them together so they won't fret and cause the problem.
Not sure if this is the problem with yours, but it may not hurt to check it out.
File Type: pdf
Old Nov 24, 2015 | 05:09 AM
jdlew's Avatar
jdlew
Thanks for the reply's
Old Dec 21, 2015 | 06:23 AM
jdlew's Avatar
jdlew
Replaced all 4 wheel bearings. Problems are gone as of now.
Old Dec 21, 2015 | 06:51 AM
wayback's Avatar
wayback
What and where did you get them? Thinking about doing this myself.
Old Dec 21, 2015 | 09:35 AM
jdlew's Avatar
jdlew
Amazon. Got the timken's. For the set it was close to $800
Old Dec 21, 2015 | 11:36 AM
cclive's Avatar
cclive
Well, I guess that's one answer to the problem....
Old Dec 21, 2015 | 05:32 PM
jdlew's Avatar
jdlew
After a couple of months it progress to kicking off the ABS, Service Active Handling and Service Traction Control lights/DIC. Which was leading me toward a wheel bearing. I dont have access to a Tech II for free to find out which bearing was kicking off the codes. Car has over 90,000 miles, so I went ahead and just replaced all 4 and called it maintenance due.
To New Active Handling Problem, Help please
