Oil Pan Torque Sequence ?
Old Nov 24, 2015 | 10:38 AM
cmonkey713's Avatar
cmonkey713
Default Oil Pan Torque Sequence ?
Does anyone have the torque sequence for reinstalling an LS-2 oil pan? Since removal and install is such a pain I just want to make sure the sequence is correct. The mating surfaces have been cleaned and inspected, contacted Permatex and have the correct sealer and application procedure and a new GM gasket. All I need now is the sequence for the torque on the 17ea. 10MM pan bolts at 106inch pounds. Thanks
Old Nov 24, 2015 | 12:09 PM
Don-Vette's Avatar
Don-Vette
I would start in the middle working out to the sides in a criss cross pattern increasing torque gradually.
Old Nov 24, 2015 | 12:57 PM
cmonkey713's Avatar
cmonkey713
Is there a torque sequence in the service manual that can be accessed by link somewhere?
Old Nov 24, 2015 | 01:28 PM
jft69z's Avatar
jft69z
The GM procedure doesn't show a specific sequence, but it appears there are 2 different bolt sizes, with 2 different torque values.
If attachments don't work, PM me with email address & I'll send it out.
One procedure is for "in vehicle" replacement & other is for "out of vehicle" replacement. Looks like a little different info so I included both.
Joe
File Type: pdf
To Oil Pan Torque Sequence ?
