New Lift: What maintenance first?
Just installed a Bend Pak 4-post lift, and I need an excuse to use it (No pics, the garage is still a disaster area)
I have a B&B Fusion axle back setup, which will be installed by lunch, then planning to flush the clutch fluid.
This is the first time I could easily get under the car. Any other things I should be looking at right away?
I Fly Low (12-02-2015)
Received 2,887 Likes
I have something vibrating at take off. Just started this week.
Might be the heat shield I hope.
Depending on year and milage fluids might need changing.
Also clean radiator and condensor. I do it once a year.
The first thing I did when I got the car up was drop the sway bar for exhaust removal. The first bolt I touched on the sway bar bracket was not even finger tight! It had begun backing out, and I would have lost it soon. Good advice. Is there somewhere listing torque values for major components? I don't have a service manual yet.
