I have a 2005 Corvette and the push to start button is dead. Prior to today, when the button was pushed you good hear clicking activation prior to the engine starting, however when pushing the start button now there is nothing. Both fobs and all accessories work and the battery is fully charged. Any suggestions??????
Could be as simple as a bad button/switch or serious as a bad BCM.
Are you DIY capable or do you know someone who is? It would be nice to try to check the continuity of the switch and wiring or you could just throw a new switch in.
Not DIY capable with electronics, what is a BCM and if bad what is the replacement process for that?
No, everything seems to be normal with all proper readings, its just as though the push to start is dead.
I still need more info...when you say 'all proper readings'...if the button is simply not working, then there should readings at all. Do you mean that the gauges all cycle and the dash lights up when you push the button?
Does the light on the switch come on? I would try disconnecting the battery for a minute first.
Hey thanks for the advice, I unhooked the battery for a few and after I reconnected it the car cranked. All seems to be working ok right now. Your tip helped me out. Thank You.
Could be your battery needs replacing. What you described is symptomatic of a battery going bad. Do you know how old the battery is? Also could be a bad connection at the battery terminals. Vettes are really fickle when it comes to proper voltage and power. Sounds like you're OK for the time being though. Good luck!
