Looking at a C6
Old Dec 20, 2015 | 05:02 PM
yellowvette1992's Avatar
yellowvette1992
Default Looking at a C6
C4 member here. I have owned a C4 for 13 years now and am looking to upgrade to a 2006 vert. Daytona Sunset Orange(Yellow would be my first choice - lol) Automatic with paddle shift, heated seats, power top, navigation, adjustable suspension. My question is there anything special to look for in a C6 that would be different from my C4. Oh yea the car has just under 20K on the clock. Thank you for opinions and advise. SAVE THE WAVE
Old Dec 20, 2015 | 05:40 PM
ssmike56's Avatar
ssmike56
I have an '06 DSOM but it's not a vert. I love it! A couple things come to mind regarding an '06. Check to make sure the harmonic balancer is not wobbling. Also, the early A6 transmissions would do well by getting a tune update, makes a world of difference in shifting and drivability. Other than that just go for as low mileage as you can in your budget and know what you're buying, ie: maintenance records, ownership etc. Good luck!
Old Dec 20, 2015 | 05:50 PM
yellowvette1992
I should add that according to carfax it has been serviced regularly it just passed emissions testing, but the serpentine belt was replace this past May. Is that unusual with this low of mileage or does it have something to do with as ssmike56 stated the harmonic balancer may have an issue? Thanks again.
Old Dec 20, 2015 | 06:11 PM
Never-Enough's Avatar
Never-Enough
Nothing unusual about any routine maintenance. stop looking for trouble
Old Dec 20, 2015 | 06:18 PM
R&L's C6's Avatar
R&L's C6
The LS3/LS2 of all years is somewhat subject to the harmonic balancer going out. If they replaced the serpentine belt it could have been squeking because the harmonic balancer is bad/wobbling. Check that out.
Old Dec 20, 2015 | 06:48 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Is this `06 at a dealership? Ask them to print you a GMVIS report - that will tell you all the maintenance performed on the car at a GM dealership.
Old Dec 20, 2015 | 06:51 PM
thehaggis's Avatar
thehaggis
You can also check GM VIS that may give you an idea about its service and warranty history, if they used GM service center.
Old Dec 20, 2015 | 06:53 PM
ssmike56's Avatar
ssmike56
Take a look at the harmonic balancer while the engine is idling, it should not have any wobble. The tell tale sign of a problem is a squeaky belt so if has been replaced I'd check it out.
Old Dec 20, 2015 | 06:56 PM
KABAL182's Avatar
KABAL182
Take a good look at the shocks, check for leaks. The F55 is expensive to replace. I would check maintenance records , and would change all the fluids as needed. Good luck with your purchase.
Also there was a recall on early 2005, 2006 for a steering column problem, on tilt tele a wire could be cut with use.
Old Dec 20, 2015 | 07:14 PM
Moman01's Avatar
Moman01
Serpentine belt on 2006 could just be cracked from age not mileage.
Old Dec 20, 2015 | 07:19 PM
ssmike56's Avatar
ssmike56
True! Hope so!
To Looking at a C6
