Blinker issue
Old Dec 28, 2015 | 11:52 AM
Cor CP 21's Avatar
Cor CP 21
Default Blinker issue
Hey guys,
My high beems turns on when I indicate to the right. Is something wrong with my indicator or the wiring? Thanks!!!
Old Dec 28, 2015 | 12:04 PM
Yellow95's Avatar
Yellow95
From my experience with my C5, sounds like a problem with the multi function switch. This stick that controls the lights seems to control every light on the car. When the contacts get dirty all kinds of funny things can happen.
Old Dec 28, 2015 | 12:17 PM
bgspot's Avatar
bgspot
I agree. Same experience with the C5. I don't think much changed between the C5 and C6 as far as the wiring. If that is the case your hazard light switch may be going bad. The part is cheap, but its a bit of a pain replacing.
Old Dec 28, 2015 | 12:55 PM
Kent1999's Avatar
Kent1999
You've got a bad indicator /combo switch. They are not that expensive... like $45 from any forum vendor. Replace it.
Old Jan 4, 2016 | 09:45 AM
Cor CP 21's Avatar
Cor CP 21
Replaced the switch and now everything works!!! It was a real pain to put the plastic covers back on. Thanks guys for the info
To Blinker issue
