HUD problems. Please Help.
Old Dec 28, 2015 | 09:42 PM
HIZ06's Avatar
HIZ06
1st Gear
Default HUD problems. Please Help.
Hi guys. The hud on my 06 z06 is not working properly. It does not appear on the windshield. When I look at the hud from outside, looking down into it, I can see the green/blue display, the brightness/dimmer switches and angle switches all work because I can see it react when I press the brightness and tilt buttons. The fuse is good also. Any advice? Thanks
Old Dec 28, 2015 | 10:08 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Old Dec 28, 2015 | 10:46 PM
4SUMERZ's Avatar
4SUMERZ
You have a broken pivot point on your HUD. It has been an issue, and is fixable if you remove the HUD. Here is a video showing you the problem, and the fix. The duct can be cut using a rope saw.
Good Luck
Old Dec 29, 2015 | 08:23 PM
Dcasole's Avatar
Dcasole
Good Luck
What he said ..... just pull the cluster ,Cut the duct with a PVC Pipe Wire saw , take off 2 10mm nuts and one 7 mm screw and its out ...30 min job to take out and put back in .
Dave
To HUD problems. Please Help.
