I got a message yesterday that my left rear tire was a little low on air. When I got home, I tried putting some air in it, but it's not taking air. At first, I thought my inflating tool was broken, so I tried a different tire, and it works just fine. I seem to remember something I read on here about this, but I cannot find anything. Do these get dirt in them, or get "stuck" to where they won't take any air? Anything, short of just replacing it, that I can do to "Free" it up?
Have you tried pushing the core of the valve stem in? Only thing is, the valve can release but not return to the closed position, causing a flat. Might want to have a tire shop look at it.
The tire shops have overhaul kits if the stem needs replacement. If the seat inside the valve is not damaged, the kit could fix it all. Otherwise the whole unit needs replacement.
You could also get away with just freeing that valve with WD-40.
Might have some debris caught. Old school trick is to jack the core in and out a few times to try clearing the debris. And as mentioned you have the possibility of losing all the air out of the tire, been there done that in the 18 wheeler.
Yea...real simple. Just buy a valve core remover and check it out.
Absolutely just change the valve core stem, but I'd jack that wheel up so that you don't have the possibility to break the bead on the tire while it's sitting there flat OP.
One advantage of runflat tires is that you can let all the air out and the tire will sit there looking exactly the same as always, so you can't really do any damage. I would agree that removing the valve core and checking it is a good idea, as long as you have the ability to re-inflate the tire afterwards.
