Back up camera install need help
Old Jan 8, 2016 | 12:40 PM
Z5108's Avatar
Z5108
Default Back up camera install need help
Im about to install my back of camera on a 2011 GS.
What is the best way to install. I know I have to tap into the reverse light wires for pos & neg wires.
Where do I tap into with the other wires?
Also the screen will be mounted above the center air vents.
any advice will help
see pic below
Old Jan 9, 2016 | 10:44 AM
4SUMERZ's Avatar
4SUMERZ
1) As you mentioned, tap into the rear back up light for the camera power.
2) For the monitor power, get a fuse tap, and use a fuse in the passenger footwell that will be only powered when you start the car.
3) Both the inside car Receiver and the monitor positive (red) wires will use the same fuse tap.
Find a place to put the negative (black) wires for the transmitter and the monitor power source cable.
Once this is wired, then once you have the car running, and put it reverse, the camera will power up from the BU lights, and the monitor and receiver will already be powered and will turn on with the camera transmission.
Old Jan 27, 2016 | 01:04 AM
Z5108's Avatar
Z5108
Bump
Old Jan 27, 2016 | 10:33 AM
bdanyluk's Avatar
bdanyluk
I powered my back up camera, with ALL power wires coming of the reverse backup lights. That way both the screen and the camera ONLY comes on when in reverse. Very low voltage needed, so it doesn't affect anything. You can use a fuse if you wish, on the positive wire where you connect it to the bulb wires, but that's already fused as well, in the fuse box.
Do whatever you are comfortable with.
Old Jan 27, 2016 | 02:22 PM
PaulEddie's Avatar
PaulEddie
I wired the display into the mirror. Double taped the display between the sun visors.
Old Jan 27, 2016 | 03:03 PM
bdanyluk's Avatar
bdanyluk
I installed a piece of bent metal into my air vent, and holds my camera. No wires showing, no interference with doors or anything else in the car. Works perfectly.
Old Jan 27, 2016 | 03:16 PM
MikeERWNC's Avatar
MikeERWNC
Is that an aftermarket radio?
Does it not have video inputs? You should check!
I wouldn't want that cheesy monitor anywhere in my car.
Old Jan 27, 2016 | 05:01 PM
v1 rot8's Avatar
v1 rot8
Old Jan 27, 2016 | 06:46 PM
MikeERWNC's Avatar
MikeERWNC
If you have not bought the kit yet, and your radio has video inputs, you can buy an under 20.00 camera and wire it in in under an hour.
To Back up camera install need help
