Door panel grommets
Door panel grommets
I'm going to be replacing the speakers in the doors tomorrow and figure I might as well replace the door panel grommets and pins while I'm at it. I've had the panels off before but didn't look too closely at the grommets... Do I just pop these out with a flathead? How do they come out exactly - are they glued in or just pins hold them?
When putting the new ones in, do I need to use an adhesive on them, such as epoxy?
Thanks for any advice... just want to make sure I'm prepared once I get the panels off.
They pull apart, here's a link to them.
http://www.clipsandfasteners.com/Sea...12&Search.y=19
