I'm having a vibration issue at high speeds anything over lets see 60 that i cant seem to track down where its going from. just got the 2010 GS vette about 4 months ago. all 4 tires are new. road forced balanced,aligned and nuts on wheels torqued to spec. Ive checked tie rods and and all other possibilities for something being loose. the car only has 26k miles. any idea what else can it be. i had an 2002 before and it never acted like this one. i read somewhere that it could be a bad rotor but wouldn't it vibrate when braking? it doesn't BTW. HELP!!!!
hey Boomer the Wheels are OEM, when they did the road force balance they told me one of the front wheels was at .18 that compaired to the rest that ranged from .04-.08 results. i had that wheel repaired and now its reads .07
I hope you find the answer. I have a 96 4 Runner that has had a high speed vibration, steering wheel shake, for the last 2-3 tire changes. I have taken it to everyone to find the solution. It is better but still present.
The only thing I haven't done is change the rims. But then it was fine for the first 100,000 miles with the same rims.
Oddly it comes and goes too in severity, I think mostly due to temperature.
I have given up and just drive the car at 60 mph anything above and it will shake. Not my road car just around town and short highway driving beater.
im running the tires at 32 PSI i wonder if i up them a little to say 35 PSI if it will be less of a vibration?
It's possible you have a bad tire, but that should also show up in the road force. I don't see how it could be a rotor since warped ones only show up when you apply the brakes. I suppose the rotor could be out of balance but as far as I know there's no way to balance them.
Have you had the alignment checked? Wouldn't think that would cause a vibration over 60 but you never know. And there are probably other, more expensive causes, such as drive shaft. But my knowledge of cars is extremely limited.
had the allignment checked and redone and nothing. funny you mentioned the drive shaft. wouldnt a bad shaft do it also at lower speeds?
Miami - Two things come to mind, both of which I had on my 2012GS.
Lower outer window molding that flutters above 60MPH. This is a somewhat common prob. Easy isolation tip: Tape down the lower molding at the windshield, under the wipers, and go for a drive.
The second is a bent wheel or out of round/flawed tire that can be isolated by a tire shop.
Goodluck and report back.
I had the same problem. Tried all the aforementioned solutions. Turned out to be the steering rack. Replaced the rack because it was leaking and the vibration was gone.
can you tell it was leaking? i show no signs of leaking anywhere on mine
hey 1RB
yeah im leaning to another bad wheel that wasn't picked up by the first shop i did the original road force im going to take it this Monday hopefully i can figure it out soon its driving me nuts!!.
btw what does the lower outer window molding have to do with the vibration? btw my car is convertible
The lower molding vibration is a high frequency vibration that comes from the dash area. Affects Verts, too. As the molding deteriorates, it becomes very loud as speed increases. Some say it sounds like a swarm of bees. Doesn't happen on all cars, and is very easy to isolate, and fix.
A bent wheel that's within reparable limits can be straightened by a good shop for apprrox $100, including rebalancing. That's what I was charged in Nashville last year.
Hopefully yours is one of the above or some other easy fix.
I think he's referring the the molding at the bottom of the windshield. They can make a vibration noise, obviously you have something different if you can a feel the vibrations rather than hear it.
i had both rear shaft replace cus they were leaking the vibration had gotten better do you think that the drive shaft it self is messed up? and not the wheels?
will a bad drive shaft the one that goes from engine to trans cause the vibration at high speeds? Ive got no vibration at all at lower speed.
I bought brand new wheels and tires off tire rack for my camaro. Mounted them, torqued the lugs correctly and hit the highway. Instant vibration at around 55+ and got worse when I went faster.
Went to sts tire and all 4 wheels were off. All 4. I saw the screen. I guess some noob at tire rack thought it was a good idea to put all the weight on one side. Making one side of each wheel heavier than the other. Resulting in wobbling which leads to vibration.
