Did a lil reading around on here didn't seem to find the full answer. What is the stock ls2 hp record. I'm talking about stock heads ,bottom end no arp hardware
Gotcha. I don't have the answer but others will chime in. Your 'stock' definition is what threw me.
I would consider any bolt on as making the car NOT stock, cam or otherwise. Opinions may vary.
Generally speaking, the category's are bolt-ons, internals, and power adders. Guys going for power that include a cam (internals), usually do heads on a LS2, or FI/nitrous too.
What kind of blower? Lbs boost? For how many miles?
The Ecs Novi Sl1500 kit with alky headers and a fuel system upgrade. 14 or so PSI depending on air temp. About 6k miles over 700hp. Lots of time spent in Mexico.
yea im around that on pump gas i also have a ethanol tune
I know with the right cam guys are seeing around 800rwhp. I'm sure there have to be some pushing even harder with larger superchargers. Ask in the FI section.
