door doesn't open...
Old Jan 24, 2016 | 03:46 PM
WW7's Avatar
WW7
I just pulled one of mine a few days ago, hit the prongs and the board with steel wool until shiny, put it back in and now it works perfectly...Total time , about 5 minites......WW
Old Jan 24, 2016 | 06:38 PM
cclive's Avatar
cclive
Originally Posted by Daviddear30
I did not know they were that cheap. Just bought 2 for $27. I have cleaned mine a couple of times already. Maybe new ones will be better.
It's important to spray the contacts with a corrosion preventative after cleaning...this will make them better than a new one.
Old Jan 24, 2016 | 08:44 PM
Rebel Yell's Avatar
Rebel Yell
Originally Posted by dpigguy
Just replace the pads. Easy to do, under 20 bucks and no worry for another 10 years.
Bought a pair off FleaBay for $17.95. Ten minutes later, and all was right with the world.
BTW, I cleaned the old ones, and saved them if needed.
Old Jan 25, 2016 | 02:15 PM
slowtraffickeepright's Avatar
I replaced the door pad, fail. Next step was to replace car battery, success!
Old Jan 25, 2016 | 04:16 PM
CadVette's Avatar
CadVette
I recently discovered Radio Shack was purchased by another company and some of the stores are open. As a service engineer one of my favorite things I always used was control/contact cleaner and lubricant. In the old days it was known as tv tuner cleaner. It cleans the contacts and lubricates them to prevent further oxidation and does not conduct electricity. I've used this stuff for 30 years on all electrical connections where it is subject to moisture or humidity. Great stuff. Just clean the contacts first with fine grit sandpaper.
Old Jan 26, 2016 | 12:05 AM
Mike Sr's Avatar
Mike Sr
Thanks for all the information. I cleaned both of my doors tonight and they work 1000% better. I'm tackling the trunk switch tomorrow.
Old Jan 26, 2016 | 01:50 AM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
Take the pad off, clean everything, reinstall. Fixed.
Old Jan 26, 2016 | 08:30 AM
EVRose's Avatar
EVRose
A little late to the party there Professor.
Old Jan 26, 2016 | 11:51 AM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
This place has alotta knowledgeable people in many different areas; and most of them are nice people. My original problem was resolved due to the information I was given here.
777
Old Jan 26, 2016 | 06:46 PM
HBsurfer's Avatar
HBsurfer
777
Happy to hear you did it yourself. Save a few bucks and very satisfying.
