Reverse Warning!
Old Jan 27, 2016 | 03:45 PM
JAsVette's Avatar
JAsVette
St. Jude Donor '14-'15-'16
Default Reverse Warning!
Is there some kind of warning sound if you don't have your Vette in reverse in an M/T before you exit the car? I have an '05. Also, not that I would want to but is there a way to turn that warning sound off? Just wondering.
Old Jan 27, 2016 | 05:59 PM
vetteright's Avatar
vetteright
Nope, no warning. However, I believe that there was a software re-flash available for the '05s from the dealer which, when loaded, precludes the necessity to shift into reverse to avoid discharging the battery when exiting the car.
Old Jan 27, 2016 | 08:34 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
I have an 05 M6 vert. If I don't shift into reverse when shut down I get a message on the DIC. The door will not automatically unlock unless I am in reverse.
Old Jan 28, 2016 | 07:54 AM
WW7's Avatar
WW7
...If this isn't enough to get your attention to shift into reverse, then you need to buy a 2006 or newer Vette....WW
To Reverse Warning!
