Battery date coding
Old Jan 27, 2016 | 07:11 PM
88redconvert's Avatar
88redconvert
Default Battery date coding
Just bought a 2012 c6 and am trying to determine how old the battery is. Anybody know how to determine the age. 85H7YR is on the top. Is that a date code? Thanks in advance for any help.
Old Jan 27, 2016 | 08:13 PM
okie08vette's Avatar
okie08vette
Here is what I found about codes on AC Delco batteries.
The warranty date code is located on the top label of the battery. The first character is either a P or S. The next two digits determine the month, the third digit is year and the fourth digit indicates the manufacturing plant. For example, P 098N means the battery was made in September 2008.
Old Jan 27, 2016 | 08:17 PM
okie08vette
Goggle that code with battery date codes and you will get a ton of info about how different manufacturers code their batteries.
Old Jan 27, 2016 | 08:41 PM
88redconvert
Thanks for the info. I did figure out that 85H7YR is a part number not a date code. I could not find a date code anywhere. Maybe the label with the date code fell off. Thanks for the help
Old Jan 28, 2016 | 02:04 AM
C6topless's Avatar
C6topless
Some batteries have a separate sticker with the date hole punched on it ... the bad thing is these stickers come dislodged quite easily ... especially if they are hit with some engine dressing .
Old Jan 28, 2016 | 05:35 AM
vcheng's Avatar
vcheng
Have the battery load tested. If it passes, who cares how old it is as long as it works well.
Old Jan 28, 2016 | 05:50 AM
Don-Vette's Avatar
Don-Vette
When in doubt,throw it out!!!
My "rule of thumb"
Old Jan 28, 2016 | 07:40 AM
_05C6_'s Avatar
_05C6_
If the vehicle is a 2012 and the battery is original, that would put it at 3 year old at best. Without knowing the history, or you might, I would keep an eye on it.
Our cars are notorious for 'battery' issues.
Old Jan 28, 2016 | 08:26 AM
jimmie jam's Avatar
jimmie jam
My battery is 9.1 years old. I will replace when it dies...
Old Jan 29, 2016 | 12:12 AM
okie08vette
Hope it does not fail when you are out in the middle of nowhere. 9 years old it deserves a rest retire it.
To Battery date coding
