Dyno numbers are in
Old Jan 28, 2016 | 01:38 AM
C6vette57's Avatar
C6vette57
Default Dyno numbers are in
355hp 350 tq lt headers x pipe magna flow muffler slp intake and intune 2
Old Jan 28, 2016 | 05:58 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
ok .......
Old Jan 28, 2016 | 06:16 AM
Don-Vette's Avatar
Don-Vette
Originally Posted by Turbo6TA
ok .......
Old Jan 28, 2016 | 07:12 AM
let er eat's Avatar
let er eat
I'm gonna say u lost power...
Old Jan 28, 2016 | 07:37 AM
_05C6_'s Avatar
_05C6_
That does not sound right.
Old Jan 28, 2016 | 07:43 AM
veloz's Avatar
veloz
who tuned your car? numbers went the wrong way
Old Jan 28, 2016 | 07:49 AM
Never-Enough's Avatar
Never-Enough
Super low numbers
Old Jan 28, 2016 | 07:55 AM
Boomer111's Avatar
Boomer111
Before numbers would be helpful.
LS2 auto?
If not something is wrong.
Old Jan 28, 2016 | 08:29 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
If it is an LS2 I would think the numbers should have been closer to 375 hp. That is figuring with the mods it most likely is around 440 at the flywheel and then figure a 15% lose puts it around 375 number. Now we all know that different dyno's give different numbers, but I still think this one is off. Did you do a pull before the mode?
Old Jan 28, 2016 | 08:41 AM
Boomer111's Avatar
Boomer111
Just giving the benefit of the doubt.
AGREE LS2 AUTO SHOULD BE HIGHER.
Before numbers are what is important to show gains.
Old Jan 28, 2016 | 09:04 AM
let er eat's Avatar
let er eat
Well, if he's running the canned diablo tune with those long tubes it probably running lean as fawk...not sure if the engine will pull timing on that.
Old Jan 28, 2016 | 09:27 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Year of Vette?
Auto A6 or A4 (if 2005)? Stall in Auto - locked or Unlocked on Dyno run?
Rear gears on Auto?
MN6?
Do you know the type of Dyno? Mustang/Dynojet?
Do you have the Dyno chart? does it have the AFR on it too?
Thanks,Matt
Old Jan 28, 2016 | 09:41 AM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
Those look like LS1 numbers.....Or bone stock LS2 #'s. I would be pissed if my LS2 was throwing those #'s down after those mods. I'd throw in the towel and get an LS3 vette.
Old Jan 28, 2016 | 11:27 AM
C6vette57's Avatar
C6vette57
Yes guys I am very very disappointed I actually posted this in the wrong area I habe the other post in tech fourms anyway yes first off we took out the tune to do a first pass it was 345hp after we installed the canned tune it only gained 5hp after that they played with it and gain another 5 I am very disgusted that the numbers played that way I don't know what's wrong I habe a 6 speed manual with ONLY 17,000 miles
Old Jan 28, 2016 | 11:45 AM
veloz's Avatar
veloz
no offense but those canned tune are junk,,,i never had any luck with them...think about it..it was a tune developed from some data that the mfr'r has or has developed and it is hoping that regardless where you live (geographically speaking) it will adjust your ecm to work better...makes zero sense to me.i went back and forward with the customer rep three times,,i sent him my datalog, he would change it a lil bit, i would re install it ...did this about three times and got tired of it...thing is it could damage your engine because of not knowing how the engine would react........i took mine off sent it back got my money back and went to a dyno shop and got the perfect tune..something to think about..
Old Jan 28, 2016 | 12:12 PM
J3TVETTE's Avatar
J3TVETTE
Looks low to me, find a new tuner.
Old Jan 28, 2016 | 02:25 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Yes, I don't blame you for being upset with those numbers. I have ARH long tubes, X-pipe with hiflow cats, and a tune. These were on the car when I bought it, but talked with a local tuner that had a great reputation and he feels the it is most likely 440-450 at the crank and around 375-385 at the wheels. A6 and it is sideways at the first to second shift and chirps the tires when it hits third.
To Dyno numbers are in
