I've had my vette since 2008 with almost no problems at all. Lately while driving down the road the car will pop all errors up. Will light up like a Christmas tree.
I can stop the car and turn it off and back on, and only the little yellow lock icon will still be on in the car. My car won't recognize the FOBs at times either.
I replaced the car battery. The dealer replaced the batteries in the FOBs (that was worthless for $100).
I will need to buy a code reader from Autozone tonight. They have one for $100 dollars.
If you can wait a couple of days, they have much cheaper ones on Amazon. I've seen them as low as $15; I bought one for about $50. If you have Prime it can be in your hands in two days.
Had the same issue with my 05, ended up being loose battery connection. The OEM ones are crap in my opinion. Went to AutoZone and bought some replacements, haven't had a problem since.
May want to check this first, as others have posted, the likely problem.
Swing back the lever on top of the blue connector plugs to remove and check that all the small pins are visible and not pushed back in the plug.
Clean with electrical contact cleaner, let dry and re-assemble, confirming the plug goes all the way into the BCM unit.
Thanks for all the posts. I've been riding my motorcycle lately. What I've tried so far: Cleaned the blue connectors. Bought a Xtool U581, but no error codes are displaying and no error codes to clear. Live data looks good. Maybe cleaning the blue connectors worked.
