How Reliable Are 2007/2008's ?
Entertaining the idea of getting a used 2007 or 2008 C6 but I am concerned with long term reliability of these GM cars. I know the 2007 had the LS2 and the 2008+ had the LS3. Looking for something under 50k miles.
The autos had the 6L80E, correct?
What things should I look out for?
I bought an 08 in August 2012 with 18K miles on it. It is a daily driver and now has 45K on it. I replaced the tires soon after I bought it and put a battery in it last week. That is it.
08 I bought with 38K from original owner 3 years ago
Not a DD, think I have 46K on it now so I do drive it, and only thing I have done is brakes/rotors
Original owner had put Michelin's on, I have nothing to compare it to but he said Michelin's were LOT better ride than factory Goodyears
I guess only issue you can expect is the normal popping a creaking with the top if you get a removable hard top but that is not a huge deal
They are very reliable cars overall. The biggest concerns you would have to worry about on a C6 would be the harmonic balancer or an oil pan gasket leak (both labor intensive repairs). Everything else is minor. Just maintain in properly and you're good to go. Change the oil, change the differential fluid with Dexron LS oil if it isn't been done, install Michelins, and drive it!
Received 1,675 Likes
You'll be fine with either one you choose.
Received 1,136 Likes
Either there never was a problem, or the previous owner did the fixes.
Received 1,500 Likes
I'm the original owner of an 07 with 71k miles and I have spent $250 in repairs out of warranty, I perform all the regular maintenance at home. Still on original plugs/wires/brakes/rotors.
Heres the difficulties you'll run into here. A lot of forum dwellers seem to have different opinions on what reliable is. Some will say they are very reliable and then will list several things they have had to fix. Some will say they aren't reliable because they blew out a tail light bulb. So in other words, good luck on any info you get here and take all suggestions with a ton of salt. In my humble opinion, if one wants to call reliability the inclination of any car to break down and leave you stranded then the C-6 isn't to much worse than any other car, with a few exceptions of course.....first thing that comes to mind is the infamous "stuck in park" that seems to be quite common on the A-6s. Bottom line.....do some research and take nothing as religion. Good luck.
Race Car Tech
The 2007 or 2008 drive trains are pretty much bullet proof. Like any other car or truck, regular maintenance/oil changes, brakes, etc. are all part of owning a vehicle.
In 75K miles, I have replaced the water pump at 30K miles.
I replaced the brake pads at 50K for ceramics, and the original pads were
only 1/2 worn. I'm on my original shocks, but I will change them out soon.
I did change the sway bar end links when I changed my brake pads, just cause I could, not because they needed it.
Can't go wrong with either.
I am over protective of my car because I need for work and I travel very long distances in it.
I have no problem throwing money at any minor issue to resolve it.
Maybe if I had to factor in labor rates that would change.
The Harmonic Balancer was the worse job I had to do on the car...
I am about to replace the steering rack because of a broken drive belt mishap.
Still considered minor to me because I was able to drive the car home, over 100 miles.
I bought my 08 from a Chevrolet dealer almost a year ago with 69,000 miles on the odometer. It now has 73,000. Fortunately the dealer performed some of the normal maintenance items while the car was still under the 90 day warranty, such as replacing the hood and hatch struts, the sway bar end links, the differential and trans fluid (because of a popping sound when making slow sharp turns), etc. Some of the known problems I have encountered are the headlight lenses protective coating peeling and requiring replacement. My A6 shifter cable had a problem, as do many other C6's with the A6, requiring replacement. The biggest expense for me, and the one that there should definitely be a recall on, was the dreaded gas smell, which in my case required the driver's side fuel pump, gas tank, and filler tube be replaced. That cost me $3000 because my car being an A6 required the trans to be removed to gain access to the tank and fuel pump. In my case it should have only cost $2000 as I believe there was nothing wrong with the gas tank itself, but the dealer thought it had a leak as well. The plastic fricken gas tank was $997 from GM. Hopefully if there ever is a recall, I will get a refund.
Huskerman (02-02-2016)
Original owner 07 with 53k miles. Had the differential noise when new TSB - dealer changed fluid. Had slightly noisy roof - dealer changed mounting pin rollers I think, also a TSB - quiet since, no creeks. Both those problems were free fixes. Had switch for the rear back up lights go out in my 6 speed - about $100.
Basically best car I've ever owned after 5 mustangs, a 350Z, RX-7, CRX, Camaro, etc.
I still have my 07, with 51k miles, which I purchased new. The only problem I have had was the transparent roof developed a crack after a year and was replaced under warranty.
Normal maintenance items, new tires and brake pads (ceramic) with no other issues.
It is my third and best Corvette and has been a great car for me.
