Road Repaving
Old Feb 1, 2016 | 04:52 PM
tim32311's Avatar
tim32311
Default Road Repaving
Today I drove on a road that is being repaved. Actually prepped for repaving I guess, since they have 'stripped' the old asphalt off of the top and will pave tonight.
At any rate, a lot of the debris has gotten on my C6. Immediately upon returning home I washed the car. Most appears to have come off but on the front of the car there is an area that feels like sandpaper that will not wash off. Can't really see it, but feels rough unlike the rest of the car where the wash mitt just glides over.
Any suggestions as to how to get it smooth again?
TIA
Tim
Old Feb 1, 2016 | 05:04 PM
Russkier's Avatar
Russkier
Use paint thinner or mineral spirits. (same thing). Wax as soon as you are done.
Old Feb 1, 2016 | 05:25 PM
unclecookie's Avatar
unclecookie
Before using paint thinner on your car, I suggest you try a clay bar.
Old Feb 1, 2016 | 05:26 PM
4SUMERZ's Avatar
4SUMERZ
Been there, had the same rough feel. I used Bug & Tar remover, but paint thinner and or mineral spirits do the same thing.
Old Feb 1, 2016 | 05:29 PM
EVRose's Avatar
EVRose
with clay bar. That stuff does miracles.
Old Feb 1, 2016 | 07:04 PM
tim32311's Avatar
tim32311
Will do, guys. Thank you!
Tim
Old Feb 2, 2016 | 11:13 AM
JerryC5's Avatar
JerryC5
Cruise-In I Veteran
Cruise-In II Veteran
I use WD40 to remove tar.
Old Feb 2, 2016 | 02:56 PM
HBsurfer's Avatar
HBsurfer
WD40 is magic stuff. Removes almost anything and does not damage the paint. Been using it for years on road tar, sticker residue, etc. Give it a try.
Old Feb 2, 2016 | 03:07 PM
K7MXE's Avatar
K7MXE
Myself I would clean it with 3m product 08987 .
General purpose adhesive cleaner but its also tar remover and the tar sticky stuff is gone in a second or two and wipe off with a rag but put a fresh side of the rag with each wipe. The tar will drip like water with this product but leave your paint alone. I think Amazon has the best price but been quite a while since I needed a refill.
End of problem, period.
Old Feb 2, 2016 | 03:30 PM
tim32311's Avatar
tim32311
This isn't tar or sticky stuff, it's debris from after they prep the road (looks like the used a grater to scrape the old pavement off.
Old Feb 3, 2016 | 04:56 PM
K7MXE's Avatar
K7MXE
Has to make you wonder what is causing it to stick to the paint.
What ever you do I recommend you dont use swirl motions as I did that with what I thought was simple tar. It had grit in it and I had a nasty looking hood when I was done. Made the mistake of using paint thinner. I wonder what a pressure washer might do.
Old Feb 3, 2016 | 07:39 PM
GOLD72's Avatar
GOLD72
Old Feb 4, 2016 | 11:38 AM
61X's Avatar
61X
Don't forget to throw that wash mit away.
Old Feb 4, 2016 | 10:35 PM
ICU2TV's Avatar
ICU2TV
clay bar it first. Once you do you will see/feel the smoothness.
Old Feb 7, 2016 | 08:36 AM
tim32311's Avatar
tim32311
Default Road Repave
And the winner is:
Everyone that uses or suggested clay bar! I am now a believer. It easily removed the gritty material from my car without doing any damage. My car is beautiful again.
Thank you all for the suggestions.
Tim
Old Feb 7, 2016 | 10:14 AM
Don-Vette's Avatar
Don-Vette
Turtle wax bug and tar remover. Werd!!
Old Feb 8, 2016 | 04:12 AM
mcc978's Avatar
mcc978
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17,’18,’19
Originally Posted by tim32311
And the winner is:
Tim
I have used a clay bar to remove road grime from my vette. It even worked on removing paint overspray.
To Road Repaving
