2007 Coupe RPO Code Question
Old Feb 3, 2016 | 06:35 AM
dfinkw's Avatar
dfinkw
Default 2007 Coupe RPO Code Question
I've been through the sticky, and other sites but still can't seem to find some of the RPO codes listed on my "new" 07 C6 as listed in the PIC below. I've found most all, but still wondering what the following codes mean: E2C, IL6 (maybe IL8), R6K (I don't have an OnStar mirror), R9Z, SLL and the 841/846 numbers. Anyone know what these are? Thanks in advance for your help and assistance. BTW - Loving my "new" C6 better than my "old" 00 C5.
Old Feb 3, 2016 | 07:52 AM
jimmie jam's Avatar
jimmie jam
Google is your friend.....
Corvette 2007
AAB
Memory - Driver Convenience Package
AG2
Adjuster Pass ST - Power, Multi-Directional
AJ7
Restraint System - Seat, Inflatable, Driver & Pass, FRT & Side
AK5
AQ9
Seat - FRT BKT, Luxury
AR9
Seat - FRT BKT, Deluxe
AU5
Lock Control, Entry - Remote Entry, Low Power
AU8
Lock Control, Entry - Remote Entry, Specific Frequency
AX4
Restraint Conversion - Seat, Man, European
BAG
Parts PKG - Export
BGR
Plant Code - Bowling Green, KY, USA
BV7
Bumper Provisions - FRT & RR, Canadian Requirements
B4H
Modification - Noise Control, Export
B4P
Modification - Noise Control, Transmission Control Module
CC3
Roof - Hatch, Removable Panels, Plastic
CE4
Washer - Headlamp, High Pressure
CF7
Roof - Sun, Removable, Non-Transparent
CJ2
HVAC System - Air Conditioner FRT, Auto Temp Cont, AUX Temp Cont
CM7
Roof - Convertible, Folding, Power
CW1
Country - Korea
C2L
Roof - Package, Dual Removable
DD0
Mirror O/S - LH & RH, Remote Control, Electric, Heated, LT Sensitive
DD8
Mirror I/S R/V - LT Sensitive
DL5
Decal - Roadside Service Information
DL8
D42
Shade - RR Compt
EXP
Export
FE1
Suspension System - Soft Ride
FE2
Suspension System - Ride, Handling
FE3
Suspension System - Sport
FE4
Suspension System - Special Ride & Handling
FE9
Certification - Emission, Federal
F55
Chassis - Continuously Variable Real Time Damping Magnetorheological
GME
Ornamentation - Extr "GM" Mark of Excellence
GB9
Label, Limited - Consignment - Delete
GM8
Axle Rear - 2.56 Ratio
GU6
Axle Rear - 3.42 Ratio
JAF
Brake Provisions - Europe
JL5
Control - Manual Trans, First To Fourth Gear Skip Shift
JL9
Brake System - PWR, FRT & RR Disc, Antilock, FRT & RR WHL
J55
Brake System - Heavy Duty
J56
Brake System - PWR, FRT & RR Disc, Antilock, FRT & RR WHL, Heavy Duty
KNR
Cooling System - Axle
KNP
Cooling System - Trans, HD
KPS
Cooler - Oil, Engine
KA1
Heater - Seat, FRT
KJ5
Protector - Shipping, Shock Absorber
K05
Heater Eng - Block
K63
Generator - 110 AMP
LS2
Engine - Gas, 8 Cyl, 6.0L, SFI, Alum, GM
LS7
Engine - Gas, 8 Cyl, 7.0L, SFI, Alum, GM
MAE
Marketing Area - Europe
MYC
Transmission - Auto 6 Spd, HMD, 6L80
MM6
Transmission - Man 6 Spd, Tremec, 85mm, 2.66 1st, 0.50 6th, O/D
MN6
Merchandised Trans - Man 6 Spd Provisions
MX0
Merchandised Trans - Auto Provisions, O/D
MZ6
Transmission - Man 6 Spd, Tremec, 85mm, 2.97 1st, 0.57 6th, O/D
NA3
Emission System - Japan
NE1
Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs GVW (use 2003 mdl yr)
NF9
Emission System - General, OBD MIL Suppression
NK4
Steering Wheel - Sport Leather
NP7
Steering Column - EEC Approved
NT4
Emission System - EEC 05
NT7
Emission System - Federal, Tier 2
NU1
Emission System - California, LEV2
N33
Steering Column - Tilt Type
N37
Steering Column - Tilt, Telescoping
QL9
Wheel - 18 X 9.5 FRT & 19 X 12 RR, Polished
QG6
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Aluminum, Styled
QG7
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Polished
QX1
Wheel - 18 X 18.5 FRT & 19 X 10 RR, Aluminum, Painted, Flangless
QX3
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Chrome, Flangless
Q10
R8C
Control - Sales Item No. 53
SSG
Graphic - Switch Function Symbol
T62
Lamp System - Daytime Running - Delete
T79
Lamp - Fog, RR
T84
Headlamps - RH Rule of The Road, E Mark
T85
Headlamps - LH Rule of The Road, E Mark
T90
Lamp - Signaling & Marker, Export
UA2
Theft Deterrent Sys - Export Specific
UD4
Alarm - Vehicle Speed, 120 k/h
UE1
Communication System - Vehicle, G.P.S. 1
UH3
Indicator - Low Tire Press, VAR 2
UG1
Opener - Garage Door, Universal
UJ6
UJ9
UK1
Frequencies - Japanese
UK3
Control - Steering Wheel, Accessory
ULS
Lock Control - Steering Column
UL2
Frequencies - European
US3
Antenna - Diversity
US8
Radio - AM/FM Stereo, SEEK/SCAN, CD, Auto Tone, Clock, ETR, MP3, RDS
US9
Radio - AM/FM Stereo, SEEK/SCAN, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UV6
Display - Head Up
U2K
Digital Audio System - S - Band
U3U
Radio - AM/FM Stereo, SEEK/SCAN, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3
U3Z
Radio - AM/FM Stereo, SEEK/SCAN, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3, VICS
U19
Speedometer - Inst, Kilo & Miles, Kilo Odometer
U52
Cluster - Inst, Electronic
U65
Speaker System - 7, Custom
U66
VBX
Language Label - Arabic
VDD
Vehicle Information - DVD, Customer Orientation
VA5
Language Label - English
VB1
Label - Shipping, Japan
VC4
Label - Price/Fuel Econ, Puerto Rico & Virgin Islands
VC5
Label - Shipping, Except US, US Possessions, or Japan
VH5
Plate - Vehicle Identification
VK3
License Plate Front - FRT Mounting PKG
VL4
License Plate Front - FRT Mounting PKG, EEC
VL6
License Plate Front - FRT Mounting PKG, Japanese
VZ3
Label - Mercury Disposal Notification
V73
Vehicle Statement - USA/Canada
V76
Hook - Tow
V78
Vehicle Statement - Delete
V87
Vehicle Statement - Gulf States Organization
W11
Navigation Disc Data - Nav Data 1
W12
Navigation Disc Data - Nav Data 2
XFA
Tire Front - P275/35ZR1 8 BW TL HW4 EMT
XFV
Tire Front - P245/40ZR1 8-88Y BW HW4 (EMT)
XGN
Tire Front - P245/40ZR1 8-88Y BW HW4 (EMT) HI - Performance
YFJ
Tire Rear - P325/30ZR1 9 BW TL HW4 (EMT)
YFX
Tire Rear - P285/35ZR1 9-90Y BW HW4 (EMT)
YGJ
Tire Rear - P285/35ZR1 9-90Y BW HW4 (EMT) HI - Performance
YF5
Certification - Emission, California
Z5X
Mirror Provision - Arabic Language
Z49
Export - Canadian Modify Mandator Y base Equip
Z51
Performance Package - Handling
1SA
Package - Option 01
1SB
Package - Option 02
1SE
Package - LZ Option 05
1LT
Package - LT Option 1
1LZ
Package - LZ Option 1
2LT
Package - LT Option 2
2LZ
Package - LZ Option 2
3LT
Package - LT Option 3
35T
Top Color - Gray Beige (05)
37T
Top Color - Titan Gray (05)
41T
Top Color - Black (96)
Old Feb 3, 2016 | 08:03 AM
jimmie jam's Avatar
jimmie jam
From Google search also.... http://www.c6registry.com/facts/2007.htm
Old Feb 3, 2016 | 08:37 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Neither one of the above answered the OP's question since they did not include the RPOs listed. This one is closer:
http://www.longroof.info/pdf/rpo.pdf
A couple of the RPOs still are not listed but they fall into categories and are therefore probably similar to ones that are. All appear to be sales or processing oriented (rather than "options").
I believe the 84I (light titanium) and 846 (ebony/light titanium) are color codes.
https://www.bowlinggreenassemblyplan...VetteStats.pdf
Old Feb 3, 2016 | 08:41 AM
jimmie jam's Avatar
jimmie jam
You're only going to get one gold star for "being closer". It's difficult to track everything because it's often published in different places.
Old Feb 3, 2016 | 09:07 AM
Cruiser1964's Avatar
Cruiser1964
Google is your friend on this. Try doing each code by itself. I spent several hours looking for every code when I first got mine and found they didn't really matter much. Happy Hunting
Old Feb 3, 2016 | 10:10 AM
dfinkw's Avatar
dfinkw
Default Thanks -
Thank you - that SPID is fantastic. It is by far a more complete listing than the other items I had found previously. It did complete those unknown items. Appears either the original dealer/owner received an expedited delivery. At least it doesn't show some weird option I would have been surprised by when the dealer stated a required part was going to cost more "because".
Old Feb 3, 2016 | 10:11 AM
dfinkw's Avatar
dfinkw
So true!!
To 2007 Coupe RPO Code Question
