Headers question
Old Feb 5, 2016 | 05:13 PM
G Wrecks's Avatar
G Wrecks
Billy Boat long tubes bolt up to the stock x pipe. You will no longer have cats though.
Old Feb 5, 2016 | 05:17 PM
Chrisguga's Avatar
Chrisguga
Yes, brand new... only out of the box to inspect them. They're still in the plastic wrap.
I'll call you tomorrow after I double check shipping isn't $300 or something rediculous.
Old Feb 5, 2016 | 05:19 PM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
that's fine.
Old Feb 5, 2016 | 06:15 PM
Z5108's Avatar
Z5108
I'm in Tennessee I can come get them.
Old Feb 5, 2016 | 08:13 PM
Not So Fast's Avatar
Not So Fast
Originally Posted by billyboy47
one more thing. if they do fit my GS with the npp system, where do you live and how do we arrange payment? call me at 570-588-1432
Your a Wildman Billy, jumpin right in there You going "cat less" ???
NSF
Old Feb 5, 2016 | 10:07 PM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
NSF
NSF, I know nothing about headers so I have no clue where I'm going. seriously, not being mechanically inclined I have a shop here in my area that does whatever I need done on my car. All I know is that I'm thinking of putting a set of headers on my car and I WANT TO KEEP my npp exahaust. If that means going without the "cats" that's fine. Let me ask you, if you were going with headers, what approach would you take?
Old Feb 5, 2016 | 11:15 PM
Not So Fast
As far as I know you CAN keep your NPP AND have headers with cats, which is the only way I will/would do it. All that you need is for the X pipe to have a 2.5" exit so that it matches up with your stock exhaust.
The ones you are dealing with just needs the correct cats & X pipe, but I'm no expert.
Your Vette I believe has 4 cats (2012 and later) so you would wind up with just 2, whereas the 2011 only has 2 to begin with.
I'm sure someone more knowledgeable will chime in.
This is why I asked when Hinson would offer a complete package
Good luck Buddy
NSF
Old Feb 6, 2016 | 10:10 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Exactly .... That is what I have on my 2011 GS.
In my case, I installed a set of Pfadt headers along with the Pfadt catted X-pipe (you can get the matching X-pipe with cats or without cats).
The ends of the X-pipe will attach perfectly to your existing NPP over the axle muffler system (nothing else needed to buy).
If you have a base Corvette, or a GS, make sure you order the X-pipe made for the Base or GS car. This X-pipe will have the 2.5" diameter ends on the X-pipe that matches up with the 2.5" diameter inlet pipes on your existing muffler system.
However, if you have a Z06, you need to order the X-pipe made for the Z06. The ends of the X-pipes expand out to 3" so as to attach to the larger 3" inlet pipes on the end of the Z06's muffler system.
Nothing to it .....
Old Feb 6, 2016 | 10:37 AM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
Good luck Buddy
NSF
Thank you sir.
Old Feb 6, 2016 | 12:52 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
Catless will need a tuner to turn off the rear O2 sensors or you will get a CEL. A tune would be a good idea anyway you go.
Old Feb 8, 2016 | 10:32 AM
Z5108's Avatar
Z5108
Average price for a tune?
Old Feb 8, 2016 | 10:50 AM
simplegto's Avatar
simplegto
$300 to $460.
http://www.fasterproms.net/services.html
Old Feb 8, 2016 | 04:07 PM
  #33
billyboy47's Avatar
billyboy47
St. Jude Donor '17
I was told by a speed shop in town that a tune isn't required when installing headers. so, who's right?
Old Feb 8, 2016 | 04:11 PM
  #34
simplegto's Avatar
simplegto
You are right if you have Cats. If you go without cats you will have a check engine light. That can be turned off by a good tuner.
Old Feb 8, 2016 | 04:27 PM
  #35
_05C6_'s Avatar
_05C6_
They are both correct, for reasons explained.
Old Feb 8, 2016 | 04:41 PM
  #36
billyboy47's Avatar
billyboy47
St. Jude Donor '17
so then it won't hinder the performance of the headers install without a tune? Am I missing something here? then why is everyone so uppity on getting a tune when installing headers? I know, a lot of questions.
Old Feb 8, 2016 | 04:48 PM
  #37
_05C6_'s Avatar
_05C6_
A tune is best to optimize the headers. Also an intake is recommended in conjunction with the headers/exhaust.
More air in and more air out changes things a little.
But to answer your question, headers installed without a tune won't damage or harm a thing, but you will be missing out on performance.
To Headers question
Old Feb 8, 2016 | 05:10 PM
  #38
billyboy47's Avatar
billyboy47
St. Jude Donor '17
ahh, you answered my question, thank you very much.
  #39
Not So Fast
Forum says the OEM intake far surpasses the air supply needs of a stock motor I believe ????
If I do headers AND cats I will still get a before and after tune on a dyno to know just what I spent all that money on
NSF
Old Feb 8, 2016 | 10:33 PM
  #40
Turbo6TA's Avatar
Turbo6TA
Yup ... The OEM air filter on the LS3 is the same as is on the LS7 / Z06 engine.
If this filter will supply enough air for a 505 HP LS7 engine, don't you think it will also supply enough air for your 436 HP LS3?
____________________________
As far as a dyno tune after installing headers .... You will be missing RWHP if you don't.
