exhaust
Old Feb 29, 2016 | 06:24 PM
LouieA's Avatar
LouieA
6th Gear
Default exhaust
Hi, I'm glad to be part of the corvette world. I'm a corvette rookie but I was wondering why the only two exhaust pipes are the only ones turning black from fuel? I own a 2011 GS with 6,00 miles.
Old Feb 29, 2016 | 06:29 PM
spdkilz911's Avatar
spdkilz911
You probably have the dual mode option. Is your car really quiet? Are there two butterfly valves on the two inside pipes? They only open up over 3500 rpm or if you pull the fuse or get the M2W type switch.
Old Feb 29, 2016 | 06:59 PM
LouieA's Avatar
LouieA
6th Gear
Yes sir I do have the dual mode option and did have the remote installed. The two inside tubes are the ones that turn black. I just thought it was running rich, I don't hot rod it or maybe I should.
Old Feb 29, 2016 | 07:10 PM
Zero_6's Avatar
Zero_6
Mine are black too from staying open all the time. Fuse removed. I see it as a straight pipe type of deal. No biggie.
Old Feb 29, 2016 | 07:11 PM
spdkilz911's Avatar
spdkilz911
Just the nature of the beast. Drive it like you stole it. That's what it is made for.
Old Feb 29, 2016 | 07:15 PM
11Black-GS's Avatar
11Black-GS
That is just normal build up. Driving it hard won't hurt, but it will turn the pipes black a lot quicker.
Old Feb 29, 2016 | 07:22 PM
dbirdhouse1's Avatar
dbirdhouse1
Default yup
you'll see the same in the C7 as well, nothing to bother about....
Old Feb 29, 2016 | 09:07 PM
Dcasole's Avatar
Dcasole
Mine are black too , no problems with the car, it's normal
Old Feb 29, 2016 | 09:16 PM
Mikado463's Avatar
Mikado463
get some BBQ grill paint and spray the inside of the other two, you'll feel better in the morning !………….
Old Mar 1, 2016 | 12:05 PM
LouieA's Avatar
LouieA
6th Gear
Default Exhaust
Thanks I will try that!
LouieA's Avatar
LouieA
6th Gear
Old Mar 1, 2016 | 12:09 PM
LouieA's Avatar
LouieA
6th Gear
Thanks for all the good input sure do appreciate it!
To exhaust
