Warning lights
Old Mar 5, 2016 | 12:02 AM
babby blue's Avatar
babby blue
Default Warning lights
On my 2006 just turn over 23000 miles and my service engine lights comes on then my service traction control lights come on it's been doing this for a wail any ideas on this problem or does any body know a good Chevy service center in the Denver col area some one who knows vets thanks babby blue ived found out that some dealers don't no how to work on vets.
Old Mar 5, 2016 | 08:39 AM
owc6's Avatar
owc6
How old is the battery in the car?
Old Mar 5, 2016 | 09:03 AM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Yuppers...it is at least "load test" battery time. Try a Batteries Plus...they will do it.
Old Mar 5, 2016 | 09:53 AM
Cherokee Nation's Avatar
Cherokee Nation
What are the codes?
Old Mar 5, 2016 | 10:04 AM
babby blue's Avatar
babby blue
The battery is a couple years old it carrys 14 amps
Old Mar 5, 2016 | 10:06 AM
babby blue's Avatar
babby blue
The battery is a couple years old carrys a good load on a test 14 amps thank you I'll go try it again
Old Mar 5, 2016 | 10:08 AM
babby blue's Avatar
babby blue
Originally Posted by Cherokee Nation
What are the codes?
Thank you for getting back I have done test on it every time and no codes come up
Old Mar 5, 2016 | 10:09 AM
babby blue's Avatar
babby blue
Thank you for getting back to me maybe I'll go get a new battery
Old Mar 5, 2016 | 08:47 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Always check for loose plug wires first.
Old Mar 8, 2016 | 08:18 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hello babby blue,
I’m sorry to hear that these service lights are showing up on your ‘Vette. I see that some other forum members have provided you some insight on the situation, but I’d be happy to locate a GM certified dealership in your area if that’s how you’d like to proceed.
Please send me your full contact information (including Zip Code), VIN, and current mileage in a private message if you would like me to send you a list of local dealers and put you in touch with one.
Best,
Corey K.
Chevrolet Customer Care
Old Mar 9, 2016 | 05:57 AM
Grimlock13's Avatar
Grimlock13
I had one pop off the coil completely though and got the blinking check engine light and service traction control. You could tell it was missing on a cylinder though. Putting the wire back on stopped it, but the check engine light was on solid for 3 start cycles then cleared.
Worst part was removing the coil cover that was hot as It happened after I stopped in a parking lot, as I went to leave is when it happened.
Checked for codes when the light was still on? You should have a code if the light is set If the code is clearing every restart seems like a power/battery issue but that is just a guess/hunch.
To Warning lights
