memory settings help
Old Mar 7, 2016 | 04:21 PM
mjonesjr8's Avatar
mjonesjr8
Default memory settings help
I never had this problem with my '10 but, on this '13 I go though and setup all my settings, seats,mirrors, wheel, the way I want it and hit 1 until it beeps twice but, after I shut it off and get back in it goes back to the previous owners settings. I can hit 1 after that and it goes back to mine. How do I get rid of his and make mine the default?
Old Mar 7, 2016 | 04:38 PM
wayback's Avatar
wayback
Use the other fob.
Old Mar 7, 2016 | 04:44 PM
Vette_DD's Avatar
Vette_DD
When you come back to the car to go somewhere, evidently you're using a fob other than the fob that was programmed as #1. The car "knows" what fob you got in the car with and the fact that it's not #1.
As wayback suggested, use the other fob when you're ready to go somewhere.
Old Mar 7, 2016 | 05:29 PM
mjonesjr8's Avatar
mjonesjr8
I only have one fob, is there a way to wipe it out?
Old Mar 7, 2016 | 05:31 PM
wayback's Avatar
wayback
Try programming #2 instead. Should work. #2 on door control panel.
Old Mar 8, 2016 | 12:11 AM
owc6's Avatar
owc6
Get another fob. then do the long programing on the sticky.
Never let yourself be w/o two fobs.
Old Mar 8, 2016 | 01:49 PM
cclive's Avatar
cclive
Having only one fob is begging for trouble.
Old Mar 8, 2016 | 02:32 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
ASAP
Old Mar 8, 2016 | 05:14 PM
cclive's Avatar
cclive
There is a fob out there somewhere that will open and start your car. After you get another one, use these instructions to do the check of the glovebox slot and then the long procedure to erase all current fobs and add the two that you will have as #1 and #2.
https://www.corvetteforum.com/forums...tructions.html
The settings that you have entered are stored in memory #2. You cannot change the settings in memory #1 unless you have fob #1.
To memory settings help
