Dead Horn
Mar 10, 2016 | 02:36 PM
Dead Horn
Little words of wisdom required please...
The horn in my '06 Vette has decided to quit working for spring. I have replaced the fuse for the horn but still no dice.
If I push on the steering wheel or if I arm the alarm it doesnt beep, despite being set to do so, and it was working fairly recently.
Any good ideas or places to hunt around?
Mar 10, 2016 | 05:25 PM
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
Quote:
Originally Posted by
JoshBarber
I replaced my horn last summer, got it from napa and it works great.
Before replacing check to make sure its not just the wires come lose.
Mar 10, 2016 | 06:26 PM
JoshBarber
Here is an electrical schematic of the 2006 horn circuit.
If the fuse and relay check out, then it's either a connector issue at the horn, or ground.
Mar 10, 2016 | 07:53 PM
I had the same issue with mine.
Disconnected the plug at the horns, hooked up a multimeter and had someone honk the horn, saw the voltage change so I knew everything was good up until the horns itself. Changed horns and worked.
Mar 10, 2016 | 09:28 PM
Had the same problem a year after I got my 2006 coupe. Found that the wire had come off at the horn.
Mar 10, 2016 | 10:09 PM
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Happened to mine too. My horns were full of water and stopped working. Replaced with horns from a forum member and they work great again.
Mar 10, 2016 | 10:35 PM
Marcho Polo
Full of water? Please explain.
Mar 11, 2016 | 04:59 AM
Check for corroded connections at the horn first. Sand them with fine sandpaper until clean then put a dab of dielectric grease on them to prevent further corrosion. If you can, clean the female connector with sand paper wrapped around a small screwdriver by pushing it in and out a couple of times. Quite often it's the connections at the horn.
Mar 11, 2016 | 11:02 AM
Former Moderator
owc6
The way they were mounted in my car, they were collecting water. I drive my car daily rain or shine and I guess water got in them.
I thought it was a poor design or they were mounted wrong, but when I put the other horns in they pretty much go one way, and they are pointing the same way. I should probably drill a small drain hole at the bottom or something.
Mar 11, 2016 | 12:46 PM
Thanks all!
This gives me some time playing with the car this weekend.
Mar 11, 2016 | 03:48 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
More horn . . . .
Perfect time for you to up the ante in the horn department
See
http://tinyurl.com/lcvu68e
