Glass top sqeeks
Race Car Tech
Try these tips;
tabing (03-14-2016)
I have used heat shrink on the pins and it kept the top quiet for about 8 months till it wore out. If I remember I got that fix from this site
Same here, that video will hook you up for years.
I think vaseline will rot rubber. I used Super Lube 21030 Synthetic Grease (NLGI 2), 3 oz Tube as recommended in a previous thread.
https://www.corvetteforum.com/forums...long-post.html
Race Car Tech
If the tricks in the video do not solve the squeaks, rattles and pops, then as mentioned earlier, shrink wrap the pins with electrical heat shrink and that may solve your issues.
Also, you can put an extra O-Ring(upper) on the post, and maybe even replace the original O-Ring (Lower)
Yea....pretty straight forward on this issue. You'll hit the right idea sooner or later. Good thing is that its such a simple fix that when it starts the noise again that its easy to go back and re-lube it in just a matter of minutes. I must admit though that its refreshing to see that it looks like this post is maybe all of 10 minutes old and no one has chimed in saying that their top has never squeaked and my car has 400,000 plus miles on the odo.......LOL. OOPS....i've done it now !!!!!....
If the tricks in the video do not solve the squeaks, rattles and pops, then as mentioned earlier, shrink wrap the pins with electrical heat shrink and that may solve your issues. Also, you can put an extra O-Ring(upper) on the post, and maybe even replace the original O-Ring (Lower)
BigMonkey73 (03-14-2016)
Race Car Tech
I used a 5/32" e-clip and that worked OK as well. Probably a bit tighter.
I used all the tricks, lube, shrink wrap, O-Ring, e-clip, adjusted the Rear J-Hook a bit tighter, and my top makes no noise. I do lube the weather stripping at least a few times a year.
Here is where I put my e-clip close up.
Try these tips;
https://www.youtube.com/watch?v=V49RPk3VRnk
Honestly I really hated driving my car during its *fits*. Nothing worse then on the way home from a road trip and the top squeaking. Some days I rather have 110 degree heat on the top of my head then listen to the top squeak. Thanks for sharing the video!!!
I tried the dielectric grease on the gasket , the extra orings on the post, and it still squeeked...The one that fixed my problem was to use the E-Clip on the roller wheel, this stopped it, and now no more noise...The E-clip wedges the wheel so the pin doesn't slide back and forth...The pin sliding in the wheel is what causes the squeeks on the earlier models , I believe after 2007 they started using a solid block instead of a wheel....WW
That GM weather strip lube was pricy, but it soaked in well and a little went along way. Read the description and I liked that it won't react with paint.
I put a 3/16 E clip in.... Question? Was it a very tight fit? It went on but the rollers don't seem to roll too well now. I just don't want to crack them.
Besides that it was an easy mod and look foward to putting a few miles on her this weekend
Race Car Tech
Besides that it was an easy mod and look forward to putting a few miles on her this weekend
The newer handles do not have rollers. it is solid.
Old latches
Newer Style solid latches
