spark plugs
Old Mar 21, 2016 | 07:12 PM
orca1946's Avatar
orca1946
Default spark plugs
Hi all. My car is a 2006 Z-51 vette. I have 64,000 miles on it in 10 years.
Do I need to change plugs at this point?
I plan on keeping it for a few more years.
What plugs are OEM?
Are there any better or equal plugs?
What should I pay to buy 8 and do the change myself?
Places to buy them auto parts stores - amazon.com?
Thanx to all that reply
Old Mar 21, 2016 | 07:37 PM
Vette_DD's Avatar
Vette_DD
2006 Owner's Manual says to change them at 100,000 miles.
Old Mar 21, 2016 | 07:46 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Do you still have the owners manual? AC Delco is the OEM plug. Most vehicles today can go 100K miles . Is the car running smoothly? You can change the plugs if you are handy but you need to make sure the gap is set properly.
Most any plug you get at Auto Zone, Pep Boys or your favorite auto parts store will be OK.
$1.50 to about $3.00 depending on the brand and the plug composition.
Old Mar 21, 2016 | 07:49 PM
CHEV AGAIN's Avatar
CHEV AGAIN
I changed mine at 52,000 and they looked new still.
Mark
Old Mar 21, 2016 | 08:29 PM
Cherokee Nation's Avatar
Cherokee Nation
Mark
Did you check the gap? I had Denso plugs put in my at 22,000 with the cam install. I checked the gap on a couple of the OEM plugs and they were around .060.I think they should of been at .040?
Old Mar 21, 2016 | 08:32 PM
CHEV AGAIN's Avatar
CHEV AGAIN
I did, they were fine. Yours were probably.060 when they went in..
Old Mar 21, 2016 | 09:04 PM
Cherokee Nation
You mean another GM screw up? Most plugs come pre-gaped.
Old Mar 22, 2016 | 08:29 AM
C6ToGo's Avatar
C6ToGo
Check your data. Some have complained of radio interference when changing to "any plug"
And factory iridium plugs are not $1.50.
I replaced mine at 8 years/65,000 mi with AC-Delcos. Car ran fine but did them when changing wires. Old plugs looked good so the 100k interval is accurate.
Old Mar 22, 2016 | 11:15 AM
Not So Fast's Avatar
Not So Fast
Why waste your time and money ??? Unless your bored
NSF
Old Mar 23, 2016 | 12:12 AM
orca1946's Avatar
orca1946
It seems to be running a bit rougher than I remember it.
Old Mar 23, 2016 | 01:28 AM
rwpatte's Avatar
rwpatte
Always check gap!
Old Mar 23, 2016 | 03:44 AM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
I thought the Z-51 vettes have a different maintenance schedule?
Old Mar 23, 2016 | 06:20 AM
Seadawg's Avatar
Seadawg
You only need to decrease the scheduled intervals if you track it, run it really hard, or do a lot of city type driving
Old Mar 23, 2016 | 09:33 AM
Kenny94945's Avatar
Kenny94945
Because of "electrolysis" (wrong term, yet descriptive) between alum head and steel plug, at this age, you should remove, inspect gap, re-apply anti seize and re-torque.
This inspect may limit and removal issues (broken plug, thread strip for example) in the future.
Odds are you don't need new plugs, so a $100 savings, yet the removal and re-install would be nice preventative maintenance if you intend to keep the car for many more years.
Old Mar 23, 2016 | 10:28 AM
windyC6's Avatar
windyC6
Originally Posted by rwpatte
Always check gap!
Yep...while unlikely...things can happen....malfunction on the production line....even though they are boxed a plug getting dropped just right on the trode at the retail store may cause a concern.
Old Mar 23, 2016 | 10:53 AM
DigitalWidgets's Avatar
DigitalWidgets
If you're going to do the plugs, you might want to consider doing the wires at the same time. I did mine early as well. Easy DIY job, but....I struggled with getting a couple of wires off of the plugs and ended up breaking one. Fortunately, I was doing the wires at the same time.
For my LS3 (your 2006 has an LS2) I purchased: ACDelco 41-110 Professional Iridium Spark Plug from Amazon for about $5.25 per plug. Amazon has a "this part will fit your vehicle" feature to check for your car.
I also bought "ACDelco 748UU GM Original Equipment Spark Plug Wire Set" for the wires and paid $67 for those (again, for LS3...don't know if your engine needs something different). The wires came with a little tube of goop for the connections.
I also purchase a tube of anti-seize (Permatex 81343 Anti-Seize Lubricant, 1 oz. Tube) just to put on the plug threads to make the next change easier.
Some of the old plugs were on there pretty tight....but I used a torque wrench when I put them back in and was surprised and how little pressure the recommended torque spec was (11 ft/lb for my car)....if you don't do this all the time, it might be worth it to just get a feel. It was way less than I thought it would be.
Good luck with the job!
Old Mar 23, 2016 | 01:19 PM
919cw313's Avatar
919cw313
I was joking. I know my 41U edition can go 100k.
To spark plugs
Old Mar 23, 2016 | 01:30 PM
orca1946's Avatar
orca1946
Thanx for input guys. I guess I will pull them & inspect & gap.
good idea on the anti goop.
Old Mar 24, 2016 | 10:35 PM
Cherokee Nation
Always check gap!
I do for sure!!....GM put those plugs it.
Old Mar 25, 2016 | 12:49 AM
krazy1's Avatar
krazy1
Dielectric Grease for the goop. I use C5A anti seize (Permatex has it) as it will withstand a higher temp.
