Paddle Shift Question
Old Mar 22, 2016 | 01:41 PM
Cruiser1964's Avatar
Cruiser1964
Default Paddle Shift Question
Should the paddle shift work even when in Drive and not in Sport mode? I noticed the other day while reaching up to signal to change lanes I accidently hit the down shift paddle and the car down shifted while being in drive. Is there a mod that may have been done prior to me buying it so it works all the time? Thanks for any and all info.
Oh I forgot to say I have a 13 GS
Cruiser
Old Mar 22, 2016 | 02:08 PM
HBsurfer's Avatar
HBsurfer
I think it depends on the year car you have. My 2007 paddles do not work in drive. I have read that later years do work in drive.
Old Mar 22, 2016 | 02:28 PM
spdkilz911's Avatar
spdkilz911
Yours will work in either mode. Not sure exactly what year it changed. My 08 works only in Sport mode.
Old Mar 22, 2016 | 02:35 PM
windyC6's Avatar
windyC6
Yea....thats one of the many short comings of the Corvettes paddles.
Old Mar 22, 2016 | 02:41 PM
KyJim's Avatar
KyJim
Mine is a 2013 and the paddles work in drive and sport mode
Old Mar 22, 2016 | 03:24 PM
Vette_DD's Avatar
Vette_DD
Page 9-30 of the 2011 owner's manual:
The driver may choose to briefly
activate the Manual Paddle Shift
system while in D (Drive). Tapping
either the upshift or downshift
controls will place the transmission
in Manual Paddle Shift mode. The
driver may then exit Manual Paddle
Shift mode by holding either upshift
control for two seconds. The system
will return to automatic shifting after
10 seconds of cruising at a steady
speed, or when the vehicle comes
to a stop.
Old Mar 22, 2016 | 06:32 PM
Not So Fast's Avatar
Not So Fast
Ahh, the ole car manual to the rescue again, when all else fails read it
Old Mar 22, 2016 | 06:34 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Why do they work in both D and S? I thought that's what S was for (as well as possibly changing the shift points?).
Old Mar 22, 2016 | 06:56 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
They only work for a short time in D.
As Vette DD posted above from the Manual "The system will return to automatic shifting after 10 seconds", in S mode they remain active until you switch back to Auto mode.
Old Mar 22, 2016 | 07:07 PM
Cruiser1964
Thanks All and Yes Vette DD and NSF I should have checked the manual first but Thank You for answering. In the 13 manual I think it's on page 9-26. Thought it was a little weird that a trans would allow you to do both. I'm with RocketDawg in thinking it was only going to work in Sport mode so that's why it caught me off guard.
Cruiser
Old Mar 22, 2016 | 07:33 PM
Zero_6's Avatar
Zero_6
I think all newer cars with paddle shift are like that. My sister's 2015 Camry is like that.
Old Mar 23, 2016 | 12:33 AM
simplegto's Avatar
simplegto
In drive it is nice when you pass a car and don't want it to down shift 3 gears when you nail it you just pull it back a gear and you don't have all that screaming. It is also nice to down shift when you take an exit ramp to slow down. In drive it goes back to auto shift after a few seconds of not using or coming to a stop. This in 2011 and newer C6.
Old Mar 23, 2016 | 01:08 AM
Not So Fast
Just discovered that today Nice feature when used right for sure
NSF
Old Mar 23, 2016 | 07:45 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
OK, that is a very logical reason. Mine's an '09 and has to be in S for paddles unless I'm sadly mistaken. Honestly never tried it in D.
To Paddle Shift Question
